Black Hole Vu+ Duo2 2.1.5
Amazing image. I'm back to Blackhole after 1.5 years on VTI and this is amazing. XBMC is still not at a level making it usable for me. It was unable to play anything off my NAS (while my small jailborken ATV2 reads everything....). Nevertheless the speed of this image is unbelievable.
One thing - I would have like to see more info on the channel banner in the skin like the resolution and the CAM info.....Is there a way to customize this or I need another skin (I am using the default since all the others could not display my Picons...).
Try "Army DarkSky HD VU BH2.x.x v.1.0". I love it, same as other Army's skins, they're best to me.
once more
Animations SETUP can be found in the Menu System
OSD and image Position can be adjusted with the plugin UI Position Setup
First install (enable) plugin in BH Speed Up.
(blue button>> Blue >>Black Hole Speed Up)
U BH 2.1.5 nefunguje Enhanced Movie Center V3,7 beta 20152013. U BH 2.1.4 to fungovalo.
For BH 2.1.5 does not work Enhanced Movie Center V3,7 beta 20,152,013th U BH 2.1.4 it worked.
Download skin with support for Enhanced Movie Center
If you use default skin (MX HQ5) or any from HQ skins you can find HQ skins with support for EMC
on BH image addons/skin server.
You can download Enhanced Movie Center v 3.7.4 Beta from BH image addons server which working with all this HQ skins.
i install this image in the internal flash ihave hdd to work with meoboot but after installing any image in meoboot the box boot with the enternal flash not by meoboot what the problem my english is not far iam for algeria tank you
You have to choose image for a boot in the plugin .
can i install black hole 2.1.4 in the internal flash and by meoboot install this new image blackhole2.1.5 in external flash has what works well
he is only new with only on post you very rude to act like this its only a hobby i am sure he never read the rules
I'm very sorry but Board Rules are exposed during User Registration and must be accpeted (and obviously READ) before flag the checkbox for accpetance .... So there is no apologize if an user don't read them ....
Perhaps. But your use of foul language is unnecessary. Out of order.
