angelofsky1980
BlackHole Driver Specialist
Use Youtube TVmytube with bh 2.1.6.1 is crashplease help.,,,
Same with me. Tried BH almost all versions, also un VTI and original VU+ imageHi. Someone has problems with Youtbe TV?. This plugin start, but I have audio but without video. I use BH 2.1.6.1
If I'm correct you FTP the Plugin unzipped to the tmp folder(some plugins are sent across zipped) once in the tmp folder of the duo2, look for them in the BH or IPK install folder. Path is Press Menu/Addons and look at both option one on top of each other being "Manually Install BH Packages" or the other option "Manually Install IPK Packages".Sorry for the stupid question. I just flashed BH 2.1.6 (I was previously using OpenATV) and I'm looking for a way to update plugins.
I've only found an "image updater function" but not a plugin one.
For example, if an update of "HDMI CEC" plugin comes out, how can I update it? OpenATV has this function...but I can't find it in BH
Thanks![]()
so I can't upgrade plugins directly from my VU+ without downloading ipk with a PC?ohso I can't upgrade plugins directly from my VU+ without downloading ipk with a PC?
This function would be very interesting because it doesn't update only plugins but system packages also. (Like on OpenATV image)
So you would able to keep your SAT device daily updated ...
That's not the way it works VU + updates and BH image updates.
VU + have no daily updates, and so frequent changes.
All important updates are already contained within the image.
Plugins you can download from our server for Black Hole image
or install manualy .
All important updates you can update from image
or we make completely new image.
But if you want daily updates you can use Open Black Hole image.
