Black Hole Vu+ Duo2 2.1.6
Many thanks for the image. Time zone of Moscow is incorrect. It is written right (+3) but one hour later actually (+4). I must use Kuwait time (+3) very unfortunately.
Installed BH 2.1.6 all works very well using DISEqC 1.1 and 1.2 for all my dishes+ all other features I use except for one which is Hbb TV. Its the same problem I've had since Hbb Tv was introduced to BH images. Out of the 5 Hbb TV Terrestrial station we have here in Australia one one works Perfect. The others either load and hang when you try to run the recording or just a case that nothing starts at all and the Duo2 just shows on the TFT screen Hbb TV Plugin. Can I please ask you guys to look at this for us down this part of the earth as to why we are having this problem.
thanks
thanks
Report this issue directly to Vu+ (www.vuplus.com) with ALL details avaiable for HBBTV services not working correctly
Don't worry about images. The HBBTV part is developed and maintained by Vu+ directly.
Can I please ask you another question.
No doubt they might ask me to turn the duo2 box on, try to use all the Hbb TV stations that don't work and maybe including the one that does work correctly and give them a log file of some kind. If this could be the case can I extract or copy the log file from the duo2 via FTP to my computer so I can send it to them. If the above is correct can you give me the path as to where I can find the log file on the duo2.
Thank you
I installed BH 2.1.6.1 on my Duo2. Previously I had installed BH 2.1.4. The box is connected to a 16/9 PAL TV through SCART.
XBMC and OpenGL animations are not available through SCART. I later read in this thread they are both available only on HDMI. I even tried to access VU+ source code at http://code.vuplus.com/git/xbmc.git/ but I found out this repository is not public. As an XBMC addon (and open source) developer I am really disappointed in VU+ behaviour (it is a GPLv2 violation).
HLS streams have many problems in StreamTV addon (but they had the same problems in BH 2.1.4). Stream switching is not handled very well. Streams often lose audio/video sync. Etc.
But the biggest bug I found is TV channels are not played smoothly. The video stutters i.e. it is played faster and then it halts to resync for a fraction of a second and after that the same sequence is repeated. This bug can easily be seen on news channels that have a ticker (for example BBC World). It is very very annoying and disturbing for the viewer. I think I'll have to revert to 2.1.4. Sigh. This release had a lot of potentials.
Could this link be useful?
http://code.vuplus.com/gitweb/?p=vu...ta-openvuplus/recipes-multimedia/xbmc;hb=HEAD
This is XBMC 11 (released in 2012) and it is not the version shipped with the latest BH.
This is the version shipped with Open Black Hole (XBMC 13) and it should be the same shipped with the latest BH.
http://git.vuplus-community.net/?p=...e-core.git;a=tree;f=meta-vuplus/recipes-xbmc;
Git can be cloned (I have yet to see what's there) but the following archive only contains binary blobs (including xbmc.helper - i.e. the plugin launcher) and IMHO it violates GPLv2: http://archive.vuplus.com/download/build_support/xbmc-support_20141202_p0.tar.gz
If you think there is a license infringement you should first ask directly Vu+ for an explanation, and if you will not receive the expected information you could eventually report the situation to the XBMC Foundation.
I've take a look on the archive but contains only libs, headers and a binary file needed by XBMC Launcher plugin to invoke XBMC from Enigma2.... This should not violates GPL license because XBMC sources are avaiable to freely downloaded from Vu+ Git server.
For other questions, ask directly to Vu+
اتمنى تدارك مشكلة iptv فهذا الاصدار 2.1.6 والسابق 2.1.5 لا يدعمان خاصية iptv وكذلك لا يظهر meoboot عند قلاع الجهاز اتمنى تدارك هاتين المشكلتين لتكون صورة بلاك هول في الصدارة ولكم تحياتي.
السلام عليكم انا واجهت مشكلة وياريت القى الحل عندك, حدث للصورة الجديدة وحصل عندي تقطيع في الاشارة تبع القنوات ارجوا المساعدة ولك جزيل الشكر
ENGLISH PLEASE IN INTERNATIONAL SECTION!
Having problems with signal with this image. Signal keeps breaking up. I update to 2.1.6.1 and its no better also
please help
you think i should go back to 2.1.4??
yo guys i got it this problim from the card get out the card from vu+.
thanks and pis out
