Black Hole Vu+ Duo2 2.1.6
Vielen dank für die Bereitstellung des Images. Installation und Aktualiesierung von 2.1.5 auf 2.2.1.6 ohne Probleme.
Bin jetzt seit ca. 12 Monaten begeisterter VU+ Nutzer
Hatte vorher die VTI Images und im Vergleich dazu gefallen mir die BH Images von der Performance und vom Layout besser,
Alles was unter VTI gut lief.läuft unter BH auf meiner Box besser.
Danke für die grosse Arbeit
PLEASE
English only in this TRD.
Hi There,
Having problems with signal with this image. Signal keeps breaking up. I update to 2.1.6.1 and its no better.
I went back to 2.1.4 and its perfect.
great image thank you guys.
1 problem I have when in stand up mode the clock display is only half the time top half of time shows not bottom half.
how can I correct this.
ps this is on the main disply not the lcd one
Can someone please answer this for me As I do not want to do a personal back up from 2.1.5 only to have trouble with 2.1.6
Thanks
I restored my 2.1.5 personal back up in 2.1.6.1 without any issue. I think you also won't see any problem.
I seem to have a problem. On a couple of occasions after I put the box into standby I have noticed something odd. When i go to view again later in day the front displays are blank and the box doesn't respond to the remote to power on, I just get a flashing white light. It does restart when I use openwebif.
Thank you for your reply. We all know what happens if you do a personal backup and use it on a new BH image when you shouldn't. Tell me whats the Difference between image BH 2.1.6 and image 2.1.6.1?
Thanks
Thanks
As mentioned in related topic, some improvements in IPTV performance.
hi, I wanted to know if someone can lead me to a skin which does PiG (picture in graphic).
Thank you
Hi,
Does this version solves the following problem with the transcoding: when i select a transcoding option with 25fps, it works but it goes to 60fps always. I have troubles to play a live stream with 60fps on my mobile device (Samsung Galaxy S4).
Anyone could help?
Thanks in advance!
Hello
First of all, thanks in advance....yesterday i loaded this firmware and everything ok
But just a question, the epg for the different channels....it shows me only the programm that is been broadcasting and the next one.....no more information about te programms for the following hours or days.
Is there any solution for that?
Best regards
