Black Hole Vu+ Duo2 2.1.6
اتمنى تدارك مشكلة iptv فهذا الاصدار 2.1.6 والسابق 2.1.5 لا يدعمان خاصية iptv وكذلك لا يظهر meoboot عند قلاع الجهاز اتمنى تدارك هاتين المشكلتين لتكون صورة بلاك هول في الصدارة ولكم تحياتي.
Hi..
I can't download the BH 2.1.6.. an error message said "You must be logged-in to do that" however i am logged in.. I need help..
After several tries.. Finally the download has started.. I'll give you my feedback after installing this new image..
Somebody knows why I can't see my picons in channel list? I have use Picon Transparent 32 bit 220 x 132 by halus 61 and I'm using them from /media/hdd/picon /usr/share/enigma2 I wrote via Telnet: ln -s /media/hdd/picon /usr/share/enigma2 but again, I can't see them in the channel list :(
Thanks in advance and congrats to Vu+ BlackHole Team ;)
YOU NOT
You have to use FTP not telnet to replace boot file
link to files is /boot/
or
/usr/share/vuplus-bootlogo/
UNDERSTAND ME
WHAT I NEED TO SEE THE FILE IN BOOT FILE WHY IT IS NOT SHOW
GIVE THE telenet LINK TO SEE THE FILE IN SIDE THE BOOT FILE
i hope you understand what i need
YOU NOT
UNDERSTAND ME
I think you have problem With FTP connection and not with files.
Telnet link and FTP link is the same link
Direct link is /usr/share/vuplus-bootlogo/
but this link is the same Linux sym link /boot/
So you can use both and is the same for telnet and for FTP connections.
Hi All,
Thanks for the upate.
Will I lose XBMC settings if I flash this image ? I used the mediaplayer2/subssuport fix and I'm afraid to start everything again.
Vielen dank für die Bereitstellung des Images. Installation und Aktualiesierung von 2.1.5 auf 2.2.1.6 ohne Probleme.
Bin jetzt seit ca. 12 Monaten begeisterter VU+ Nutzer
Hatte vorher die VTI Images und im Vergleich dazu gefallen mir die BH Images von der Performance und vom Layout besser,
Alles was unter VTI gut lief.läuft unter BH auf meiner Box besser.
Danke für die grosse Arbeit
