Black Hole Vu+ Duo2 v. 2.0.4
thanks, this was my first one..: went great
only I failed to set my wireless? I found it, but I could not save it nor connect to it.
Any idea might help??
Thanks
Go to Wlan Connection >> Adapter settings >>usb Wlan adapter>>
1. Scan Wireless AP
2.Do you see yours.
If you see go to it, and press the OK or green button
3.Go to Adapter settings
4.Use Device ON
5.Use DHCP YES
6. ESSID >There already should state the name of your Wi-Fi
7.Method> choose Metod (example: if you use WPA2 choose WPA2)
8. Key >>Write your key
9.Press OK >> OK >>
Exit with red button and exit button
When you configure
Check if it works
If not restart your box and go back to Adapter settings
check if active if not enable ON
and try agn.
If you using static IP but also for DHCP you have to check
Nameserver settings and if not enter the address of your router.
Check twice if adapter enabled and config OK and Nameserver settings (Gateway IP from your router)
When almost all fine, till I reached tuners and motor function. I almost did but something happened...why/what I don't know...
I found a much bigger problem: I have no channels really, only some are really working....
When ever I try to changer/fix my tuner config. I get a green screen with crash report?? and restart???
I have even tried to flash BH again but did not solve it for me,
there are no real good information about this part, nor online nor in the review.....I would really appreciate your help and comments
I connected my satellite to B.
Hi folks can I ask you all a question I do I put in the ****** and the ******* into the due with the new black hole image I have the solo 2 and I can't get thee ****** or ******** into it let me know please thanks.
Hi folks can I ask you all a question I do I put in the ***** and the ******* into the due with the new black hole image I have the solo 2 and I can't get thee ***** or ********* into it let me know please thanks.
Did you read the forum rules?
What you just asked is not allowed here, you just might get banned for this.
Sent from my GT-I9100 using Tapatalk 2
Hi folks can I ask you all a question I do I put in the ***** and the ********** into the due with the new black hole image I have the solo 2 and I can't get thee ***** or ********* into it let me know please thanks.
I'm in holidays. Do you want to join me? Read Forum Rules, please!
User banned for 1 week.
Read Board rules before post.
post your sat config, do you use motor or what? What do you mean by 'Ihave no channels really'?
Posting crash log will help as well.
since last friday i am busy with the settings. Downloading the software is easy using it, is very difficult for me, still i have no picture. Sorry I am beginner m
.do allot of stupid Qs.
Yes I have a motor, duo2 is moving it, but no channels I mean no picture..= I have a black screen.
This photo is one crashes I got the only solution was starting from the begin and flash BH again..I am crying for help
View attachment 12417 View attachment 12417
The problem seems related to a plugin called VPS.
Try to reflash BH image WITHOUT that plugin.
As we see
you put it into the image add-ons that caused the crash .
Of course it is totally wrong for someone who is just starting
with the use of satellite receiver, to add plugins before good working image
and SAT TV.
Which practically means install a clean image without any addons and plugins
and test first.
Does BH have experts in my area, who may come and help me?
I did allot in the last week but I got no more then channels without broadcast (black screen) and crash errors.
Where are you located?
