Black Hole Vu+ Solo 1.7.2 (media-tree)
Thanks
Sorry, but orginal skins on the image for the decoder vu+plus solo is very heavy
Additionally, I had some suggestions for the image Alytvn
1 - Please restart the ability to update their online image
2 - Bild scanning capabilities also enabled in the Decoder
3 - Aymyjtvn little lighter for the decoder vu+solo can
You have lighter skins on image server.
You can use older skins for BH 1.6.7 .
Didn't make an upgrade since 1.6.2 but upgraded to this release after updating the bootloader.
Is there any mean of disabling hdmi-cec ?
It conflicts with my Harmony One remote control that I use to pilot all my devices.
I don't think it can conflict with it, but you can try.
If you have any problem you can disable it.
when i formated usb sticj with reciver it is restarted and not turn on
i tasted with 3 usb and this is
why?
Had a problem om 1.6.7. with Wi-Fi adapter based on 3070 chip and return to old kernel.
String from 1.7.2 description looks like solving the problem.
Wifi drivers: rt3070 driver updated with some BH patches
What means "BH patches". Do I need any additional plugins? Or 1.7.2 correctly works with 3070 after image installation?
The Ralink RT3070 driver is included into latest BH 1.7.2 image with some patches made internally in addition to the ones writed by Vu+.
If your device doesen't work, post in the Wifi section some infos about your dognle and we can try to re-support it.
1. BH images doesen't support online updates.
2. I think the Vu+ Solo tuners doesen't support blindscan
3. What ?
hi i have a vu+ solo with BH software 1.6.4 and i m facing a problem with the external usb hard disk .The problem is after 10 minutes about of using the hard disk the hard disk is going on sleep mode (standby) but also the status in the blue panel= extra setting= hard disk shows the status is standby and it doesnt let me to change it. Please i need your help. Thanks in advance!
hi,
Thanks BH team for the beautiful and wonderful image
please can i find a buckup for vu+ solo Contains a emu *****/ccam please ?
or emu *****/ccam
hi,
or emu *****/ccam
If you write another post on this argument and you will be banned!
hello all
thank you very much for this wonderful picture
I have a question
I can not find inadyn by DCC with this new version
could someone give me the direction
thank you in advance
Hi all,
I have installed BH 172 on my VUPLUS Solo.
It doesn't work as like a flow. Could I just restore factory settings in my Solo and use the USB stick having BH 1.72 image directly, or should I flash some boot loader installed first?
So I want to know if I can just reset factory system and flash bh 172 directly without having some boot loader installed first.
Thanks in advance
Hi all,
Thanks in advance
If you have prevously flashed BH 1.6.7 or newer you already have the latest bootloader for your box and you don't need to reflash it and you can flash directly BH 1.7.2 and future images too.
Hi,
Thanks for another great release.
I have faced one problem with this new 1.7.2 image. Same problem was with 1.7.1. This wasn't the case with 1.6.x images.
Here's the background: I have my solo connected to wireless network. When I change channels from one satellite to another the whole network freezes. Restarting the network does not help. Only way to get it working again is rebooting or restarting GUI. This is my wireless info:
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0bda ProdID=8178 Rev= 2.00
S: Manufacturer=Realtek
S: Product=802.11n WLAN Adapter
S: SerialNumber=00e04c000001
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 4 Cls=ff(vend.) Sub=ff Prot=ff Driver=rtl8192cu
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=84(I) Atr=03(Int.) MxPS= 64 Ivl=125us
