Black Hole Vu+ Solo 1.7.2 (media-tree)
thank's lot dear black hole team , it's a grate job . just i have some problem in sstreaming channels in my computer by vlc player and also bad responce to web control commands.
i'm wondering , is there any plugin to record channels sound in mp3 format ? if there is , where can i get it?
just ...please issue next version with simple skin to avoid program responce delay . ( for example in scrolling on channel list)
anyway you're the best supporting team . :victory:
Hi, mu vu+solo was working fine with BH 1.6.6
I installed the BH 1.7.2 using usb stick but ... "black screen" !!!! can anybody help please :(
You must update your kernel first to load BH from 1.6.7 till now. The update file can be found here on this forum.
Reporting a bug??
Whenever i unplug Solo from AC i see that the configuration settings of web interface port are going to default (80) and it losts my previously configured port...
Has anyone else meet this one?
Reporting a bug??
After you have setted up your plugins make a full reboot of your box ... This should solve your issue.
How to use af9015 dvb-t tuner usb device with this image , there is no driver available???
Driveres are already included into image. No external IPKs needed.
Plugin your device, turn on your box and hope your device will be detected.
You can find the config params into Menu->configuration->System->Service Searching->Tuner configuration
If your device is not detected, we can start study the problem into "usb dvb driver" section.
