Black Hole Vu+ Solo 1.7.5 "Multiple"
sorry to bother you, I just need to know How I can install this version BH 1.7.5 I ' just a new guy in this VU+ world. I'm using solo.
thnaks a lot in advance guys
sylvain genty
sylvain genty
After file Dload,
Extract to USB directly,,then insert the USB into the front slut!
Wait for the process to finsh, turn-off the STB from the back,,,,wait for a moment,,,trun on the STB!
After reboot follow instruction @TV screen,,,Etc!
Search the V-C board for more details!
Make sure NO usb connected @ the back during flashing the new image and use the correct BH IMAGE for you Vu+!
Agn,
1.Format USB stick FAT32 on your PC and Unzip image file
and copy everything to a USB stick.
2.Connect USB stick in a Solo
3.Plug the power and wait until the green light.
4.Plug off power (wait for a moment) and plug ON power.
hi
i need too search the channel name in channel list
i can use reamot control number keys ( alphabets ) in 1.7.3 but in this ver i cant use it
plz help me
tnx
hi
i can use reamot control number **** ( alphabets ) in 1.7.3 but in this ver i cant use it
plz help me
tnx
It has already been written many times on the forum
pls use forum search next time.
To change this use
blue>>red>>Enable Epg Buttons in chanel list >NO>>Red (save)
Hello everybody,
How in new version of BH image (1.7.4. and 1.7.5.) we can start recording programs - in previous version until 1.7.4. we had red button for start recording, but it is now reserved for start of paralell universe?
Also, is it ok if on USB 4 Gb I make two partitions (2 Gb for each)?
Thanks
Hello everybody,
Thanks
You must use the (rec) button in the remote to start record....
Should I make 2 partitions on the USB stick, one for Universe and one for swap/picons/epg etc. Is that how it should be done?
HDMI-CEC Plugin does not work correctly with 60" Samsung UE60D8000YS (UN60D8000YF): solo is off, but tv is on, but if tv is off / solo is off.
Samsung Anynet+ (HDMI-CEC) anable.
hi to all
i have in my vu+solo bh 1.7.3.
i wanna install bh 1.7.5 ,
the bootloader is changing or not? thanks
hi all and thanks for team
i have problem in solo when i go to 26E and i change channel the solo is frizing only in badersat plz any one can help me and this problem only in blackhole when i change the image to vti evrything is good but i love blackhole
plzzzzzzzzzzzzzzzzzzzzzzzzzzz help
Hi gabo,
1st What image U have on now?
2nd Try to look at your Tuner Configuration settings, and compare with settings provided by few V-C members , here at site>use search tools!
3rd If U are changing between images, I think you are using a backup settings,,,try to make a new one if possible, and stay away from backed up images, "what work for others not necessarily work for you"!
RgdZ
a911
Hi!
I just installed this version of the image in my new VU + SOLO, and I'm trying to mount my NAS but I can not, however in my other decoder my NAS is working well.
What is the problem?
