Black Hole Vu+ Solo 1.7.5 "Multiple"
I have an external HDD 500G and wish to utilise only the rear USB port. Can I partition the HDD in 3, as media/USB, /universe and media/HDD? Or I have to do the media/USB and /universe on seperate USB and let the 500G HDD just for recording thus using also the front USB port.
You can partition your external USB HDD as you want with BH 1.7.5 up to 4 partitions :) and map these partitions as you like.
I have intsalled this Version On my box and all looks good, the only problem I have found is that after selecting restart from the menu
it hangs and nothing.
I have to turn the box off from the power and on again.
I attached a serial cable and this is what I found,
Hotplug - status.connected 0
CPU 0 Unable to handle kernel paging request at virtual address c0935370, epc == c0935370, ra == 80060844
Oops[#1]:
Cpu 0
$ 0 : 00000000 00000001 c0935370 00000000
$ 4 : 0000000d c0d19464 00020000 86fef615
$ 8 : 31008400 1000001f 804f35b0 00000001
$12 : 00000000 ffffffff 00000000 ffffff80
$16 : 865bc680 00010000 00000000 00000000
$20 : 00000001 0000000d 00000002 805e6460
$24 : 80607cf0 00000000
$28 : 86fd6000 86fd7c50 00010000 80060844
Hi : 0000002d
Lo : c6be91ca
epc : c0935370 0xc0935370
Tainted: P
ra : 80060844 handle_irq_event_percpu+0x5c/0x280
Status: 31008002 KERNEL EXL
Cause : 10800008
BadVA : c0935370
PrId : 0101954c (Brcm4380)
Modules linked in: procmk 8192cu ipv6
Process rcS (pid: 51, threadinfo=86fd6000, task=86f7f1f8, tls=77824490)
Stack : 000204d0 8060827c 00000054 80607f18 00000000 ffffffff 805e6460 00010000
00000020 00000000 00000002 b0001408 b0001410 b0001404 b000140c 80060aa0
ffffff6f 80070684 00000002 00000000 805e6460 80063830 00000000 00000041
80607cd0 00000000 80607cd0 00000000 00000001 80060408 00000000 80282434
00000041 00000002 80607cd0 80005818 00000001 8120220c 00000008 00000000
Call Trace:
[<80060aa0>] handle_irq_event+0x38/0x5c
[<80070684>] __alloc_pages_nodemask+0xec/0x670
[<80063830>] handle_level_irq+0x98/0x118
[<80060408>] generic_handle_irq+0x44/0x64
[<80282434>] kobject_get+0x1c/0x2c
[<80005818>] do_IRQ+0x18/0x24
[<800022b8>] plat_irq_dispatch+0x118/0x1e0
[<80003f6c>] ret_from_irq+0x0/0x4
[<80088094>] __pte_alloc+0x38/0x2d4
[<800250ec>] dup_mm+0x408/0x500
[<8001265c>] local_flush_tlb_mm+0x74/0xc4
[<800931a8>] anon_vma_fork+0x88/0x1dc
[<800baa64>] dup_fd+0x4c/0x360
[<80025a78>] copy_process+0x84c/0x10c4
[<80026378>] do_fork+0x88/0x220
[<8009e3d8>] filp_close+0x78/0xac
[<80008a80>] _sys_clone+0x8c/0xd0
[<8009e4b4>] sys_close+0xa8/0xd0
[<8000c5c4>] stack_done+0x20/0x40
Code: (Bad address in epc)
---[ end trace 5ad61efb332367df ]---
Kernel panic - not syncing: Fatal exception in interrupt
Rebooting in 180 seconds..
Oops[#1]:
Cpu 0
Hi : 0000002d
Lo : c6be91ca
Tainted: P
Cause : 10800008
BadVA : c0935370
Call Trace:
I think you have a clone box OR you don't have updated the CFE.
Please post ENTIRE serial output.
Maybe it is not the proper thread to post a question like this one...
Forgive me if i am wrong... (Please the Operators to remove my post if it is not in the right thread)
I just flashed my box with the latest image and i want now to connect to the net through my wireless network...
I have the following wi-fi usb stick TP-LINK TL-WN821N but i can not connect to the internet...
Moreover, i can see nowhere the stick in my image menu...
There are two options...
The image does not recognize the specific wi-fi stick or i do something wrong...
Can anyone help me with this problem?
Thanks in advance!
Thanks in advance!
What setting U have @Menu>Setup>System>Network>Adapter settings>Use DHCP.....change to Yes!
I have already tried this but no success...
My inquire is that i can not see anywhere the usb stick from the menu...
Normally, it should appear in the menu, shouldn't it?
If you have just connected ONLY USB WLAN dongle
on USB port
The image does not recognize after image reboot.
I am afraid that there is no support for TP-LINK TL-WN821N .
on USB port
I just did the above but with no success again :(
I am afraid, too, that there is no support for this dongle...
What a pity...
Isn't there any other solution?
Any code?
Any support to the next image, maybe??
One more question....
The least month i have noticed that the box is overheated, especially on the top...
I mean that "overheated" in comparison to the past of course...
But there is no change to any settings or the place of the box...
Any idea?
P.S. The processor is running as usual...
1.
only driver coder know answer to this .
2.
the ambient temperature in the summer increase ??
1. I wish he could give me a good news in the next image!
2. You are right. But i think it is abnormal to feel such a heat on the surface of the box... Never mind! The point is that the box is running all good!
