Black Hole Vu+ Solo 1.7.6
Hello with 1.7.6 version , not possible to pause/forward/fast forward not possible using nStreamVOD plugin , any ideas? regards
Danke !
Same problem here, with latest image , Nstreamplayer video forward/pause/fastforward funcktion dont work :(
"- Support 2 zapping mode(hold, mute)"
It can be changed in plugins, but does anyone know what those 2 do,and how they are different?
I noticed that channelswitching got a little slower compared to 1.7.5,despite the "Improve vtuner performance", not a big deal though.
BLACK HOLE TEAM YOURE ALLWAYS NUMBER ONE , GOOD JOB , FRIENDS
IF IT IS POSSIBLE PLEASE INSERT BLIND SCAN IN NEXT VERSION , THIS feature IS just one that others(images) got before us . anyway you are the grate , tnx lot
Solo tuners doesen't support blindscan.
Sent from my iPad using Tapatalk
Dear guys;
I just installed this black hole 1.7.6. It crashes all the time on the GUI, looking for this file: /usr/share/dvbapps2/vfd_icons/vfd_icons.
could you please help. thanks.
sylvain.
Thanks for the image and it just the best image around for the Solo.
But i have one question, when starting I recording no matter which way it then adds a time in the timer list but it doesn't record, never had this before so can someone help me out with this?.
Nevermind, after a format it worked again.
where I can find it the crash log. please help. could some one help me using direct access to my laptop and accessing the VU solo directory via mozilla.
i'm in Paris.
thanks
sylvain.
Your log is interesting... Can you try to reflash the image without restore backups?
Just one thing:
when I use Dreamstream to view/rec on my PC TV from my Vu+ Solo, streaming stops. I remember on old 1.6.6 was an option called "Enable media" to make it work, but can't see it on this 1.7.6. any idea?
hello guys I'm new and I'm trying to learn how calmly, I have a problem after you install the image the receiver turns on but stays solid green but the monitor does not get any screen, you know you help me?
As answered in another post: have you updated the Bootloader of your box? Reflash the image after bootloader update.
Hello Guys supporter, I have VU+ solo with Linksys WUSB600 v2, everything was fine in older image, after update to 1.7.6 my Wireless lan card not recognize , why ??:fie:
plz help .... tnx
