Black Hole Vu+ Solo 1.7.6
Hi guys, with this image my ntfs external usb hdd is mounted in read only mode. i was thinking that BH had the ntfs-3g driver to mount ntfs in rw mode by default. How can i fix this ?. For information mounting manualy the hdd with the ntfs-3g command, mount it in rw but if i restart the box i lost the conf. i don't know how to change /etc/fstab to force the box to load my hdd in ntfs-3g mode. please help me.
Please don't cross post the same messare around the Board. This mean SPAM.
Sorry, i was thinging that in this thread i will be more lucky to find answers.i did some test yesterday and i think that BH 1.7.6 did not mount my hdd using the ntfs-3g but the ntfs drivers. this explain that manual mount with ntfs-3g command worked (rw) but the automount with the fstab file not worked (ro).​
i wanted to install the last drivers of ntfs-3g (2012/01) in place of the 2011 drivers contained in the bh 1.7.6 but i didn't succed (the config.guess didn't guess the build type of the vuplus solo to compile it). can someone explain me how to do this installation (hoping it will solve my probleme).thank's​
Hi guys i use blackhole 1.65 and this morning download ver 1.76 and install to resiver solo then have not any graphic in reciver .
help me?
help me?
You need updated bootloader for images newer than 1.6.6.
Update CFE, reflash image and you have OK.
There is a problem adding timer using WebControl.
Saving a new timer I get the error message:
The parameter 'channelOld' can't be empty
and nothing is saved.
Sorry ,
I have a question, you might be think that i am silly!
but i must ask and i hope you can help me.
i download latest version 1.7.6 but i don't know how can be flash it or how can upgrade my version of vu solo (it is 1.6.6).
i will so happy that teach me how can be done after i download the 1.7.6
thank you
Sorry ,
thank you
Simple.
Update CFE of your box and next flash the image you want.
hi i have created a bouquet with my channel list but when i press 22 for a channel , the info bar displays 29 and for the rest displays --- like this photo below
why>>>??
osd1-jpg.7943
Hello Dear all,
First of all, thanks for the image.. I have problem with the Image to be working on VU+SOlo. I have tried to installed more than 3 times but after successfull installation, no dispaly appears even after 5 minutes. I copied vusolo folder on 2GB USB stick whcih has free space 250MB. Image installs successfully and when i restart my box nothing shows up even after 5 minutes.. I tried to installed 1.42 and it works well.display appears. Please advise how i can make new BH 1.76 usable for me and to be working on my box.
Thanks in advance.
Hello Dear all,
Thanks in advance.
What is the colour of the main led of your Solo box?
Seems locked in some bootup stage.
First of all take the BH image (or a Vu+ official image too), unzip it and place vuplus folder (and their content as unzipped) into the root of your USB flash disk and retry flash process.
Hi angelofsky1980,
As per your instructions above, i have done. problem is solved . Im running new BH image 1.76. Its great image by BH team. Appreciate their tremendous efforts and knowldge... Thanks a lot for your help.
Best Regards,
