Black Hole Vu+ Solo 2.0.3 Hyperspace
hello to all,
who mounts the new images ... from 2.0 onwards ... I do not work anymore '
the decripkey wrong 'sees the pen VLAN but' always error ...
CIFS works. There's still the same old bug. If server who has serving the cif goes standby or disconnect, BlackHole goes crazy and hang on when requesting access to it.
IT'S A KNOWN "BUG" FROM ALL VERSIONS I MOUNTED (FROM 179) :-(
Try this
1) BH: mount cif and access it (from gui or telnet /media/net/XXX)
2) CIF SERVER: make standby or disconnect network
3) BH: access now cif (from gui or telnet /media/net/XXX) --> BH hangs
4) BH: reboot, access now cif (from gui or telnet /media/net/XXX) --> BH connects (goto 2)
It's not a image bug. It's a CIFS protocol limitation.
MY TUNER STUCK!!!! I DOWNLOAD THE LAST IMAGE 2.0.3 HYPERSPACE IN USB STICK, BUT THE TUNER SOLO2 DOES NOT WORK! PLEASE HELP IF YOU KNOW. MANY THANKS.
At first, please, don't shoot by writting in capitals.
What doesn't work? You should write about your configuration. Dish, LNB, sat to receive, box configuration and so on.
Writting only "tuner does not work" is too generic and doesn't specify a problem.
Thank you.
