Black Hole Vu+ Solo 2.0.3 Hyperspace
File "/usr/lib/enigma2/python/Blackhole/BhSettings.py", line 1415, in updateFeed2
File "/usr/lib/enigma2/python/Blackhole/BhSettings.py", line 1429, in updateList
File "/usr/lib/enigma2/python/Blackhole/BhSettings.py", line 1445, in checkInst
IOError: [Errno 2] No such file or directory: '/tmp/bhspeed.tmp'
(PyObject_CallObject(<bound method BhSpeedUp.updateFeed2 of <class 'Blackhole.BhSettings.BhSpeedUp'>>,()) failed)
</enigma2crashlog>
<pythonMD5sum>
<!-- Cannot allocate memory -->
</pythonMD5sum>
</crashlogs>
</opendreambox>
@lacierva: Your Image is corrupted, you have to reflash. Afterthen I suggest to you to create on USB universes and SWAP and to use Avalon for your plugins and other stuff.
just sused it before you posted and mounting now, i take it then when i download any plug in i will get the option to store it in universe ?
Sorry, I don't understand. You have to install BH in flash, next make two partitions on USB flash, install universes, select Swap to USB.
now so far so good have created the swap and universe, and can access universe and bh speed up without crash, i still have not downloaded epg, will this store on the swap file as well as the picons ? thanks for all the help, i think i am close to have image running perfect
You have to configure CrossEPG to save data on USB.
after downloading epg from bh rytec to usb, the box greenscreens when universe is selected
all was ok till download of epg, must be corrupting something
Rytec server has some problems. Try to "search". I don't remember now, where is exactly thi stuff. It's a fresh issue.
