Black Hole Vu+ Solo2 1.7.9-3
my tunner setings are direct from them likra rotor cst rotor vannibal rotor... buth the problem is not the settings
on vu+ solo duo uno all work greate when i update fpga
on vu+solo2 not worck
Tuner configuration is one thing, and SAT list/settings another .
How do you have configure motor in tuner configuration.
thx for all support for the bigining i use almost all vu+ products
all on rotor sistems on vu+ uno solo duo after update all data rotor settings local positon longitude latitude..after that i must update fpga
if i not update fpga on rotor sistem will not worck i see no chanel avaliabele signal 0
on vu+ uno solo duo all worck fine after fpga update
on solo 2 i have a problem whit that on rotor sistem signal o
if i reboot vu solo 2 on hotbird or on athers ... worck on that satelite where the vu was rebuted buth when i try to muve on ather sattelites signal is 0
Then really I do not know
I have no such problems with my Solo2
and I also use rotor.
I have tried all buth not work on rotor only if i make a reboot on specifi satelit wil worck only there also i see anather problem on tunner B not worck signal o on all method hope to fix the rotor problem in new version of black hole
Is birtrate viewer plugin incompatible?
It worked fine on solo1 but doesn't load now.
Please fix it. Very useful plugin.
What are your tuners settings? Matrix already asked you that but you have not replied.
I know you're experienced user however nobody's perfect and you know - every little helps :p;)
I have an issue when using the loop through function. When I have my single LNB cable connected to tuner A, I get a SNR around 90% and all is well. However, when I configure tuner A to loop through to tuner B the SNR drops to around 30-50%, meaning that most of the channels fail to tune in.
My configuration is:
Tuner A: loopthrough to tuner B
Tuner B: simple, single, Intelsat 10-02/Thor (0.8W), no DiSEqC
Is this to be expected or am I missing something?
You can use Black Hole Personal Backup plugin to backup and restore your settings.
Thank you for your reply.
Do you mean I should flash the image via front USB and overwrite the current one? then restore the settings from backup?
Is there any other straight foreword way?
Personal backup is create on hdd [you have posibility to changed his place to other].
When you flash new image to box and imag will be run you mast only restore this personal backup.
AL youe setup[ skin; setting; setup AV; setup satelite; and more and more] from old image will be on new image now.
Nobody has any input for this problem? Or am I posting in the wrong thread?
That means that you connect antenna on the B and not on the A connector.
It is a good configuration for PIP and recordings from different transponders.
A Tuner configuration 16 'Eutelsat is written Eutelberd 16'
and when I'm searching for channels, finds nothing of this satellite
I can not check because I am using ready-list and I have no problems on 16E
Are you sure that the problem comes from the image??
I have not heard before.
But you can download a ready-made list from our image server
and check .
I'll check next time if I re-install image.
