Black Hole Vu+ Solo2 2.0.2 - Meoboot Revenge
maybe im wrong but i think that bug is not in Transponder.py, becouse this file is identical (binary) like Transponder.py in image Vuplus. Vuplus image work ok....
i think that bug is not in Transponder.py, becouse this file is identical (binary) like Transponder.py in image Vuplus, but Vuplus image work ok....
vuplus image doesn't use that function.
test this please.
if this doesn't work it is needed more work in e2 core.
gs
not pauseable.
[AutoRes] service changed
  File "/usr/lib/enigma2/python/Navigation.py", line 43, in dispatchEvent
    x(i)
  File "/usr/lib/enigma2/python/Components/ServiceEventTracker.py", line 38, in event
    func[2]()
  File "/usr/lib/enigma2/python/Blackhole/BhEI.py", line 144, in __start
  File "/usr/lib/enigma2/python/Tools/Transponder.py", line 45, in ConvertToHumanReadable
    eDVBFrontendParametersSatellite.RollOff_alpha_0_20 : _("Auto")}[tp["rolloff"]]
KeyError: 3
(PyObject_CallObject(<bound method Navigation.dispatchEvent of <Navigation.Navigation instance at 0x17eb058>>,(5,)) failed)
  </enigma2crashlog>
Hi,
i just installed 2.0.2 and made an online update. everything works fine, except ftp-access when running an image from usb... i always get "500 OOPS: vsftpd: refusing to run with writable root inside chroot()" - tried everything i found on the net, but it didn't solve my issue. any hints?
regards,
astrakid
Hi,
regards,
astrakid
Question is too generic. BH in Meoboot? What FTP access? From PC or MAC? What software are you using for FTP?....
sorry, here more details:
BH is installed in Flash with meoboot. on the usb-drive is vti-5.1.0 installed. when booting the flash-image (bh) ftp access is working (my PC-client: totalcommander). when booting the usb-image, it is not. trying a "telnet localhost 21" within the usb-image i get the same error as by my client, so i guess it is not client-related... the server is vsftpd, which version i don't know. but it is part of vti or bh.
kind regards,
astrakid.
kind regards,
astrakid.
I'm using Filezilla included in Vu+ Control Center (VUCC) with BH image. VTI is not supported here :offtopic: . You should ask VTI.
ok, sorry.
thought that is a simple multiboot issue... maybe i will install a bh on usb as well and test it...
kind regards,
astrakid
