Black Hole Vu+ Solo2 2.0.9.1
Hello. I face a problem with blackhole images from 2.0.4 that was my first blackhole image and till on 2.0.9.1 hasn't been fixed. I have a USB3.0 stick 8GB and i have mounted it as mnt/usb to make recordings.The flash is formated to ext1(for USB sticks if i am right). Whatever record i do in any channel, on playback i get a lot of glitches. I tested with the same device and settings other images and the problem doesn't exist. Is there something i am doing wrong? Should i make any further settings on my stb? Thank you very much!
Hello, with this update, I no longer have the sound of HD channels on Eutelsat 5 ° West on Vu + SOLO2
Black Hole 2.0.9.1​
Whats new:​
  • [blindscan] support blindscan on vusolo2
  • [OpenWebIf] update
  • [hbbtv] update
  • fix ait dump w/ multi-section
  • [blindscan] support bcm7346 tunner.
  • [Customize] add preferred tuner option.
  • [AV Settings] add PCM Multichannel entry.
  • [Frontend] fix set PLP ID for DVB API VERSION 5.9 or later
  • Update drivers 20140310
    - Fix PCM MultiChannel problem(solo2, duo2)
    - Fix vtuner PIP
    - Fix Dual tuner loop-through input from single tuner(duo2, ultimo)
  • Update drivers 20140306
    - Support blindscan(solo2, experimental)
    - Support both SCART & HDMI audio in passthrough mode.(uno, ultimo, solo2, duo2)
    - Fix no audio problem in some radio channels
    - Support PCM Multi Channel(solo2, duo2)
    - Fix timeshift problem
    - Fix loop through problem (duo2, single tuner)
    - Support dynamic contrast in PEP
    - Turn on PQ Enhancement by default
    - Add more PQ enhancement proc entries(solo2, duo2)
    - Fix vtuner problem when RestartGUI
    - Fix some CI modules recognition problem
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.​
Thanks a lot for the release, but the problem plugin 3G modem did not solved. It's now a very real issue.
Thank you for this latest release. I installed in flash via USB stick. All is working fine but I have a couple of issues I would like help with :
1. Green Panel -> Stream TV Player. None of the links work for me, and actually on some of them the system hangs with the blue/white circle flashing on screen.
2. I have a hard disk installed and can record programs but playback is not very intuitive for me. I select menu->media player then I get 2 panels on screen (file list and playlist). Should I be copying files from file list to playlist or should my recordings be automatically in playlist? Also not sure how to switch between file list and playlist panels. Is there a guide for recording and playback?
Merci, J'ai Installé la Version 2.0.9.1 et installé skin hd glass 16 et j'ai constaté que je n'ai pas de son sur les chaines HD du sat Eutelsat 5° WEST. Toutes les chaines: ART, M6, Tfi , etc....
