Black Hole Vu+ Solo2 2.0.9.1
I have just installed the 2.0.9.1. It's fantastic, but I don't understand how to enable transcoding. I was using the BH 1.7.8 before, and there in the transcoding plugin setup it was possible to enable/disable transcoding. In 2.0.9.1 I only see options about port, bitrate and framerate, but no option to enable/disable. If I try to open transcoded stream via OpenWebIF it just times out. What am I doing wrong?
Thank you very much!
Image looks nice and moves fast but I detected 3 problems:
1. I can not enable subtitles in mediaplayer (it show the "not allowed" symbol).
2. Audio in "Dolby Digital+" now is "mute" and the downmix does not work for it; in older BH versions there was no problem at all (terrestial TVE 1 HD and many "second audios" of channels from the CANAL+ package). In fact, TVE 1 HD now is full mute (all the audios use "Dolby Digital+")
3. The EPG info shows quite slow in part of the CANAL+ package (specially C+1 C+30 and C+Xtra), but I am not sure that it is a BH problem or a provider problem.
I started a thread with first problem... you, as administrator, can delete it if you consider it right.
Thanks.
Xostia
