Black Hole Vu+ Solo2 2.0.9
I've had my Solo2 for two weeks now. It has frozen on two occassions now and I do not watch that much. The only thing I can do then is switch the box off/on to get it working. The first time was watching TV the screen stood still while audio played on. The second time was watching back a recording, screen frozen and no sound.
Also when looking back recordings from HDD (BBC's Match of the Day and Football League Show) I notice loads of screenerrors.
I updated 2.0.5.3 to 2.0.9 today and everything is great besides one thing.
Font of srt subtitles is small,like in default 2.0.5 version.
In 2.0.5.3 it was much bigger and prettier.
Can it be somehow changed in skin or something?
Sent from my Nexus 7 using Tapatalk HD
Yes, in Setup menu you have a dedicated option for "Subtitles".
There you can setup his size, and put the best value for you.
Regards.
Black Hole 2.0.9
What is new ?​
  • New bootlogo by mikark
  • Add option: "Preferred tuner" Available in menu->setup->system->customise (Expert mode). Configure which tuner will be preferred, when more than one tuner is available. If set to 'auto' the system will give priority to the tuner having the lowest number of channels/satellites.
  • Black Hole weather: switch to msn provider to fix bug when town not found and implement auto-langauge.
  • Teletext: Update to the latest tuxtxt version (this fix rai hd televideo too)
  • [hbbtv] updates:
    1. works for compatibility.
    2. enhancement for seek on VOD.
    3. fix setDemension.
    [hbbtv/youtubetv] improvement player to stable.
  • switch to black-hole-aio-grab and fix bug in grab picture with pig
  • hbbtv/browser updated.
    - support seek at ARD Mediatek.
    - fix video playback bugs at Tagesschau.
  • set dvbaudiosink caps to support mpeg 4 profile LC and apply relevant patches.
    dvbapp : append gst-plugins-bad-faad on RDEPENDS.
  • [hbbtv] fix ait handling and transparency.
  • update driver
    20131230
    - Fix dual tuner problem(duo2)
  • [hbbtv] changed ait handle
  • servicemp3 : fix getSubtitleType
  • servicemp3 : fix wrong playing time.
  • [hbbtv] fix zapping delay from ait handling.
  • [hbbtv/youtubetv] fixed volume control bug.
  • [hbbtv] fixed a wrong red-button url bug.
  • [hbbtv] works for compatibility
  • [hbbtv] fix playing live stream after vod stop
  • [hbbtv] fix check vuplus
  • [hbbtv] fix crash restart after installation.
    remove useless initialization.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.​
Thanks.....
Regards.
This options is for dvb subs for satellite channels.
I'm talking about srt subs for hdd movies.
I think they work too for hdd movies.
If dont work, you allways may change directly in "skin.xml"
Dont remember what's the tag you must change, but do a search for "subtitle" on it, and you got it.
Regards
You're right! Size is for srt subtitles and not for dvb subs!
Thanks!
This Image is very Good, The Only think I do not Like is:
When you are on Favourites Channels, Let say Sky Sport Italy 1, and you press the Red Button to go to All Channels, it Take you to the First Channel which is Fun Spice Hotbird on my Case, I think that not Good, I would like to get me to the Same channels name which is S Channels, same with the Channel you are, not on the first Channel, because this is how it goes with all other Images, Hopefully Blackhole will change this on Next Image, Thanks.
I have the same issues. But after I change the HDMI cable, never happen again !
I am new to blackhole. I was using vix before. How do I go to channel settings. I dont want numbers next to the channels. Also want status bar on the right. I could not find out. Please help. Sorry if I posted in wrong section.
ZaZA
hi i cant connect to server to update my reciver... your server is block in iran...pleas upload 2.0.9.1 here to download and update my reciver by usb and upload blind scan plugin to use that on my solo 2
I'm going to pull my hair out... well what i have left of it! Got a new Solo 2 today to replace my aging VU Duo. Had it preflashed from my supplier with blackhole 2.0.9, plugged it in, went through the set up and scanned for channels but only finding 300 channels each time. My setup is, Simple, Single, 28.2E and no to send DiSEqC. I know my dish is fin because if i plug my VU duo back in i get all the channels that are missing on the vu solo2. Sorry if im posting this in the wrong place but im bit of an amateur at this but know just enough to get me going. Any help is greatly apreciated. Thanks in advance.
Just tested Transcoding on WLAN, HD crypted channel, Transcode - 1Mbps 25 fps, Android device, works great. I don't have any problems :D
Hi Paolino, which settings did you use in the transcoding plugin? i.e bitrate and framerate to acheive a hd stream?
