Black Hole Vu+ Solo2 2.0.9
It is always the problem of BH.
Obligation to flash for each version change
OpenPLi always one step ahead on this point. Online update permanently even if the version changes.
Fortunately elsewhere as it can change every night.
Advantages and disadvantages.
If this is a problem why you do not use PLI
so you can make updates every night ..
But if these updates are tested a few days by the Beta team
as is the BH image. It is another matter.
We have updates online but only for minor changes.
Major changes not.
In this way we are trying to avoid bugs
and thus you get a clean image without any residue of the old.
I wish you fun with updates every night.
:D
so you can make updates every night ..:D
But I use Pli for several years.
Before I used VTI and I changed to the same problem
This does not prevent me to test new images, including BH 2.0.9, to follow their developments.
I've already answered.
Everyone is free to use the image that it most suits him.
Our image and ideas are different from others.
Including not tested automatic image updates.
Any major change in our image has been tested by several members.
Installing clean image has its advantages over a simple update.
With that, we avoid potential conflicts with the old, not only the image but also plugins.
So the best combination.
Small updates online.
Major changes tested new image.
Intento instalar BH 2.09 en Vu+Solo2 y se queda parado en UBIFS Update... ¿Que hago?
I try to install 2.09 in BH Vu + Solo2 and just stands in UBIFS Update ... What do I do?
Black Hole 2.0.9
What is new ?​
  • New bootlogo by mikark
  • Add option: "Preferred tuner" Available in menu->setup->system->customise (Expert mode). Configure which tuner will be preferred, when more than one tuner is available. If set to 'auto' the system will give priority to the tuner having the lowest number of channels/satellites.
  • Black Hole weather: switch to msn provider to fix bug when town not found and implement auto-langauge.
  • Teletext: Update to the latest tuxtxt version (this fix rai hd televideo too)
  • [hbbtv] updates:
    1. works for compatibility.
    2. enhancement for seek on VOD.
    3. fix setDemension.
    [hbbtv/youtubetv] improvement player to stable.
  • switch to black-hole-aio-grab and fix bug in grab picture with pig
  • hbbtv/browser updated.
    - support seek at ARD Mediatek.
    - fix video playback bugs at Tagesschau.
  • set dvbaudiosink caps to support mpeg 4 profile LC and apply relevant patches.
    dvbapp : append gst-plugins-bad-faad on RDEPENDS.
  • [hbbtv] fix ait handling and transparency.
  • update driver
    20131230
    - Fix dual tuner problem(duo2)
  • [hbbtv] changed ait handle
  • servicemp3 : fix getSubtitleType
  • servicemp3 : fix wrong playing time.
  • [hbbtv] fix zapping delay from ait handling.
  • [hbbtv/youtubetv] fixed volume control bug.
  • [hbbtv] fixed a wrong red-button url bug.
  • [hbbtv] works for compatibility
  • [hbbtv] fix playing live stream after vod stop
  • [hbbtv] fix check vuplus
  • [hbbtv] fix crash restart after installation.
    remove useless initialization.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
This is free hobbyist software and it comes with absolutely no warranty. Use it at your own risk.​
Black Hole 2.0.9
What is new ?​
  • [hbbtv] updates:
  • update driver
    20131230
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
Many Thanks Great Work
1 & 2
it seems that satellite list is not good.
Install another list or make manual Scan
Dear Matrix10
First of all, let me say thanks for your quick reply.
I tried to install the other list and recording problem were removed but new issue appeared. I upload the channel list by VUCC to box and all bouquets are transferred to box with no problem but in satellite list(when I press green in channel menu) there is no satellite except the one which installed at the beginning of image installation. Is there any protection defined for satellite list from your side? I checked the Tuxbox folder and there was my favorite satellite list there but this list only works for satellite scanning. Should I scan all satellites one by one or it's still possible to transfer my sat list to box same as what I did in 2.0.7 image.
Awaiting your kind reply
Kasra
Dear Matrix10
Kasra
Im on my work now.
I not understood everything.
BUT
1.First Find a good list for E2 receivers not for E1 (enigma1).
2.Upload List with Dreamboxedit but agn in option for Enigma2
I have a feeling that you have upload SAT list and satellites.xml in the wrong folders.
Im on my work now.
BUT
Dear Matrix10
I followed your guideline using Dreambox edit and it works!
Thank you very much indeed! Now I'm able again to have all satellites and also can record with no problem. But for the picons, still there is problem.I copied my picons to folder usr/share/enigma2/, then made a link as per mentioned in this forum "
ln -s /media/hdd/picon /usr/share/enigma2/" but no channel except a few ones(Eurosport2 HD) have their picon showing. Also for EPG, nothing!
Please help me. It's really important for me to enable picons & EPG on my box.
Kasra
Dear Matrix10
Kasra
Use USB stick for Picons
Mount Usb stick and downolad picons from BH image server
If you like to use HDD
hdd has to work all the time
than picons going to /media/hdd/picon and not to /usr/share/enigma2/
Epg you can download with BH epg or Cross epg .Search forum for info.
Dear Matrix10
I changed the path of picon as per your instruction and the problem resolved. Now I have all picons activated on my box and I should appreciate you for your net efforts and decent behavior.
Also for EPG, eventually i think I've found the source of problem. Your site(Vuplus-comm...) is filtered in our country(Iran) so that my box could not be connected to dedicated URL in your site. Is there any other site containing EPG data by which I can update my EPG?
Regards
Kasra
Dear Matrix10
Regards
Kasra
Not that I know of.
Im sorry i cannot help you with Epg.
Rgd MX
