Black Hole Vu+ Solo2 2.0.9
i have GS with new BH.
File "/usr/lib/enigma2/python/mytest.py", line 591, in <module>
runScreenTest()
File "/usr/lib/enigma2/python/mytest.py", line 449, in runScreenTest
session = Session(desktop = getDesktop(0), summary_desktop = getDesktop(1), navigation = nav)
File "/usr/lib/enigma2/python/mytest.py", line 185, in __init__
p(reason=0, session=self)
File "/usr/lib/enigma2/python/Plugins/SystemPlugins/WeatherComponentHandler/plugin.py", line 27, in sessionstart
from Components.Sources.MSNWeather import MSNWeather
ImportError: No module named MSNWeather
where is problem?
what to do ?
runScreenTest()
where is problem?
what to do ?
You have installed a bad unsupported plugin (meteo in osd).
The problem is always in something you have installed not in bh image.
runScreenTest()
where is problem?
what to do ?
Bad name in Weather forcast ??
Cant get into speedup menu.Box hangs on loading.
sppedup menu have nothing to do with you problem
your problem is WHAT YOU HAVE INSTALLED NOT BH IMAGE
connect in ftp and remove bad things you have installed (first of all the folder: "/usr/lib/enigma2/python/Plugins/SystemPlugins/WeatherComponentHandler )
but the better thing is that you reflash and don't install this kind of foreign plugins.
Have you waited enough long with loading .
If you do not have a connection press Cancel and wait.
I think your problem is connection with our server.
Check your internet connection.
No Matrix he have installed the merlin plugin for msn handler with converters and renderers to have weahter in osd wrote for dmm hw.
My install was a clean one.No extra addons.Installed it yesterday afternoon.Cuoldnt use speedup menu.It hanged I left it hanging for 15 min.Restarted tried agin for 6-7 times no go.
Same thing this morning.This afternoon it suddenly worked.
Sorry i made i little confusion with previous user.
We had server problems yesterday and for this reason you had problems to connect to it.
Hi, Thanks a lot for the updated image.
One question:
***** Info (enigma2-plugin-extensions- ***** info_svn-3385-r0_all) no longer works since image version 2.2 (as far as I remember for the version).
Some dependencies are now missing in the latest images to make it work. Any fix in the pipe?
