Black Hole Vu+ Solo2 2.1.0.1
After several years of using OpenPLI I gave this one a try on my brand new Solo2 just to find out that I cant disable background scan which is driving me nuts since deleted channels keeps reappearing. Is there anyway to fix that?
Hello, I installed this image and it works perfect in my Solo2 (much better than the previous images), but I have problems with the stream in OpenWebif and in Android App Vu+ Player. Stream doesn't work, in the computer I have only a black screen in VLC and in Android doesn't charge any channel. How can I fix this problem?
Thank you very much.
I solved it, I don't have enable the second tuner. :grin::grin::grin: I enable it and now it is working.
Thank you for your great work.
Hi
I flashed this image it works fine but icant get youtube tv to work just black screen.
Can anybody help me plz?
with BH 2.1.0.1 and als 2.1.0 my WLAN device where NO DEDECTED
I use TP link and now with BH 2.1.0 and 2.1.0.1 NO work
I must go Back to BH 2.0.9 and my TP LINK WLAN device work OK
