Black Hole Vu+ Solo2 2.1.0.1
During playback of a movie in mkv format, after 2 hours approximately, a blue sphere begins to flash on the TV screen and the movie stops, finally I have to turn off the decoder. What could be the cause?
Another user report the same thing but after some tests made directly with my box, the issue is not reproducible in my installation.
I suggest to check where is the MKV file (USB, HDD or network mount point): usually HDD is the best choice if your media files are biggest and/or with an high video/audio resolution.
The mkv files, HD resolution, are saved on internal HDD already. I can't understand.
I had a same issue before- with every image- i solved it with the USB stick and SWAP file enabled- 245M- after this freezing never come back- but befor- long MKV files cannot be watched at one time-
Also i instelled a freememory plugin- it also help to clean the RAM and produce an empty space-
cheers-
cheers-
Thank you for answer. Where I need to create a swap file? HDD or USB stick?
I like this image. Artwork is best of all. All works perfect exept PCTV 290e nanoStick T2 TV Tuner. Wery often it stops working(black screen). So I moved to OpenATV where PCTV 290e works without big problems. Maybe somtimes this problem will be fixed. Then I surely will move back to BH.
i hope this is ok please don't ban me lol, can you confirm that the vpn works ,if so is there a guide thanks. solo2 bh 2.1.0.1 best image ever.
