Black Hole Vu+ Solo2 2.1.0
Hi. Can some one help me to Get picons to work ? I have the latest blackhole image.
Regards Patn
Easiest to put in /media/usb/picon
If you download from BH server, they are put there automaticly.
Green > Yellow > Addons (first choice) > Picon packages
Depending on what positions you are looking for I recommend Licher (near the bottom) But they are not complete.
Hi everyone. I installed 2.1.0 on my Vu+ Solo2 but i faced two problems:
1) After rebooting the decoder, sometimes audio does not work
2) The display of the decoder does not represent the channel I am watching. If I go on menu, it says "Menu principal", and that's ok, but when I exit menu, it remains "Menu Principal". When i change channel, it remains the same.
Someone else facing those issues? How can I solve them?
Thank you.
Default skin and clean flash? I mean without Personal Backup.
Are you italian? I am. Your nickname make me think so...
Anyway, no personal backup. Default skin, and i suppose clean flash. I read that flashing with the digital key already insert in can cause some problems. I flashed with the digital key insert on the back of the decoder. Maybe has that compromised the flashing process?
I'll check this evening, anyway it's recommended to use frontal USB slot for image flashing.
Reboot in some circumstances can create audio or various USB sticks detection problems. Especially after some writting operations to internal flash. In all enigma2 images.
