Black Hole Vu+ Solo2 2.1.0
With BH2.1.0 and personal backup from BH2.0.9.1 picture on my Solo2 is worse then with BH2.0.9.1. What could be causing this?
hi friends tnx first of all, i want to share my opinion about this new version:
a) I have noted a worse image quality than previous version,seems like lower detaild or less focused (this in sd, in hd is ok)
b) when switching to channel list menu this isn't completely black but stays trasparent to let you see the video going below
c) I've been forced to a second flashing because when switching from free to encripted service it stayed freezed on back (free) service instead to become black screen
I'm curious to hear your opinion friends.........I wait for you
cheers
Ok there is a workaround to get teletext working for those that need it.
telnet into your box and then type the command
opkg update
and press enter.
Then type the command
opkg --force-overwrite upgrade
and press enter again.
When it has finished, reboot your box and teletext will be working.
telnet into your box and then type the command :
opkg update
and press enter.Then type the command :
Is there a offline fix for this problem ?
