Black Hole Vu+ Solo2 2.1.1
Hello
have a question regarding universe.
if you have enabled universe so you have an usb stick plugged to store the universe.
wondering what happens if:
1 - unplug the usb stick and reboot your vu+
2 - shutown then plug back the usb stick then power on your vu+
I don't want to try and loose configuration :-)
Thanks.
Hi their, im using Blackhole 2.08 at the moment and I want to update to the latest version
Now iv done a full backup and a personal backup last night, but people have told me not to use my personal backup as it could have bad effects with the new kernals etc
can anybody help me as to what I can do as I want to update but my personal backup would have all my cams/ cam configs and everything inside it and I cannot lose them.
You can do it by following these instructions.
HOWTO UPGRADE FROM 2.0.2 TO 2.0.3 SAVING ALL YOUR SETTINGS
