Black Hole Vu+ Solo2 2.1.1
If can't post about EMUs, even when a emu problem related appears, how it would be solved? is a dvbapi or kernel problem in 2.1.1, this problem of simultaneus watching not appear in BH 2.1.0..
Let's be realistics, all people uses BH images for what all know...so must consideer it
NO EMU ALLOWED HERE. BANNED
Hello,
Good job! just installed it (upgraded from 2.0.8).
everything works like a charm!
The Youtube pLaye is great..
Still one thing that I couldn't make work:
I am desperately trying to make subtitles work with my avi files,
I tried dos & unix format, txt & srt, ansi & UTF8 ... and no luck.
is it a known issue?
Thanks all.
My box keeps crashing periodically, just whatching a channel, blue screen and restart in previous channel.
Sometime is a Green screen with a lot of text, at the end there’s something like “Let’s dump a bit of code, let’s hope don’t crash”
Attached two last crashlogs.
Hello,
Thanks all.
Hello ,
does anyone has an answer to my question please?
still struggling to display subtitles ...
Thanks.
Tried to update but it doesnt flash after saying checking usb!!! Ive taken my brand new solo 2 out of the box, copied files to usb as per instructions and it will not do UBIFS update...please help
Check if your usb stick is FAT32 formated.
You must extract the folder from the zip as is to the USB root.
When you see checking usb (or update found) press power.
If this doesn't work, try another usb stick.
Hope this help you!
Hope this help you!
Thank you okidokiss, used another usb stick...many thanks
hello :
*- I have a vuplus Duo2 after the flashes 2.1.1 with USB, boot logo remains blue not green were is the problem please.?????
Hello BH developers and administrators,
I am wondering what is the process to submit requests for new enhancements or bug fixes?
Thanks.
Thanks.
you can write here if you use Solo2 and this image.
We monitor forum and User Opinions and bugs.
Thanks Matrix for replying.
Two requests/wishes for christmas :)
- Having a setting that disable/enable the access to 'All' services list from channels list menu:
Display only Favourites: Yes/No
default value being is 'No' (which is the current behaviour).
If Yes , user will only have the Blue button (favourites).
this can be interesting as you don't need to setup a prental control.
(I have also mentioned this in the skins forum)
- Fix a bug with the load of black/white lists:
currently you have to restart interface t make it taken in account
commad = wget -qO - http://127.0.0.1/web/servicelistreload?mode=X
This command does not work when you want to reload blacklist.
It can allow using a crontab to have parental lock only for a time window (after midnight for example).
(I have also mentioned this in the another forum and I think you replied to me @that time)
Hi all, just a question on whether anyone gets a green screen when trying to record a live channel? it only happens when i want to record something im watching and once it reboots i can record as normal, would timeshift have anything to do with it?
Cheers in advance.
is an interesting picture has everything you need for a stable
has one small wade (skin) lack of choice to whatever I like.
(green screen) outside skinhead is all about OK
What version of HD Glass 16 is best for my VU + SOLO 2 orginal
To answer on behalf of the team, although I'm not coder
but we do have some basic principles in making images .
Basically all you're looking for
you should ask VU + because we use their original coding
and we do not want to change the basic coding from VU+
because then we have to change not only what you're asking, but also much more.
So it's different when you ask to modify our additives to basic image.
