Black Hole Vu+ Solo2 2.1.1
I do not know may be dreambox users feel nostalgia about BH !!! and managed to invite it back into their boxes LOL..
I am sure BH team is proud that BH is still popular else where...
Of course, but it violates these terms of BH image usage.
It is written with each image.
Sorry chaps, but is BH enigma2 file available open source freely for use? and is it same as VU Experimental image enigma2 file??
I wonder is there any one help, i just flashed Black Hole Vu+ Solo2 2.1.1 usb image, then after the setting transponder VU+ Hang I turned off and on, totally something goes wrong. it wont start. is there any idea what happened.
thank you all in advance
As written in an own thread, I get a green tint over the screen while using this image with Xbox One (HDMI IN), do will there be an update, or is it any way to downgrade just one of the files to get the colours back to normal? I did a test again today after Microsoft came with a new update last week, but same thing.
Hello to everybody
i am really at all of this stuffs and i need some help. I have just received my new vu+solo2 (from amazon!!!!) and this BH2.1.1 is "preinstalled"...Does it means that the vu+solo2 is a clone?.
Thank you very much for your help
Thank you very much for the link.
I checked it and it seems to be 100% original. Finding BH preinstalled filled me with suspicion. i am really satisfied with my vu+solo2....i have discovered a new world!!!!.
There are problems with the new version 2.1.1. If I run a restart of docoder the gui hangs for a few minutes and you do not see any channel.
When you perform a search with all TV channels are found only 300 channels. Some of you have or had the same problems?
You don't refer to your configuration, what satellites are you using and other useful informations about your setup.
My Solo2 works regularly.
