Black Hole Vu+ Solo2 2.1.1
With this as the last one, my HDD has been unable to mount, so I have lost all my data due to "format" my two last updates. Is it just me that has that problem, or anyone else? Anyone knows why?
B.H 2.1.1 has sorted handshake problems with AV sound system and TV. Very happy with the update. Everything works perfectly including HD mount. So big thank you B.H team.
openvpn is not working.i get the following error messages
Cannot open TUN/TAP dev /dev/net/tun: No such device (errno=19)
Note: Attempting fallback to kernel 2.2 TUN/TAP interface
Cannot allocate TUN/TAP dev dynamically
hi,
everything works great like always but where is the skin MX S line present in previous version ??
I didn't find it, possible to add it to the feed or give us an ipk.
thx.
When trying to record from any channel to the HDD I get the message couldn't record, the service is invalid.
Anyone else got this message ?
Somebody can help me? since the new update the event's didn't appear when i selected a channel.I just have the channel name without the event in progress.To get the event i need to activate the epg button.Somebody have the same problem?
Some conflict on start up with blue and green ''Vu+ Blackhole'' font, changing my screen's resolution. Needed restart to come up using blue one.
Problem to transcoding using 8001, 8002 port.
And time-zone is wrong to me.
1080p create screen resolution conflict on startup.
Have to set 1080i.
For wrong time-zone i think is the new satellite.xml that i use.
Finally, i have reflashed and transcoding is working.
Thanks BlackHole team...
solo2 hangs on Starting... when you restart it or turn the switch off. the only way to get it to work is to reflash 2.1.1 please fix it ASAP
My Solo2 works correctly after some reboots. If your box is genuine, verify if USB sticks are fully supported.
same with me it happen after memobot set up evey thing was ok on usb but when i go back to flash img it hung and no respond my aolo is genuine
it's genuine. if flashes well. I set it up. restart enigma (old gui restart) works just fine. but when restart the whole stb or turn switch off and back on it stays on starting... nothing happens. turn switch off/on again no change. hangs on starting... plugin USB stick again. turn box off and on. press power. and everything works just fine. if don't turn it complete off it works without issue. no logs. when it hangs at starting... I can't even connect to the box over ssh. so I can't provide any logs or errors
Usually if your box hangs on "Starting..." is a symptom of some attached devices (USB sticks and/or HDD) is not yet fully compatible or they have some errors and block boot process.
