Black Hole Vu+ Solo2 2.1.1
Usually if your box hangs on "Starting..." is a symptom of some attached devices (USB sticks and/or HDD) is not yet fully compatible or they have some errors and block boot process.
I haven't attached new devices. no USB hdd is connected. only sata hdd inside the box. USB stick is only connected when I flash bh image
I also tried to enable/disable meoboot. still the same hang on "starting..." in both cases. the only way to fix it is to reflash the image
Can be a SATA HDD problem. Detach it
I doubt it... just installed official image as of today, it restarts just fine, turn off/on - Starting... for just couple of seconds and than it boots just fine. just redownloaded BH, md5 shows the previous one I flashed and this redownloaded are the same. So there is no error while downloading or something. It's a BH issue, not issue of my box
Try without SATA HDD please.
I know it's forbidden to talk about cams. but one of them seams to be the one who prevents the box from booting. tried without that one. and it starts as expected. then tried a modification of bh 2.1.1 by a Russian guy (bh 2.1.1 by Pushkin). and that cam works just fine
Hi Guys
I installed the new 2.1.1 image today, but I clicked restore previous setting, does this matter?
Also my load up screen colour hasn't changed, it's still blue and not green as per the 1st page of this thread?
Also I have tried to load MSMedia but for some reason I get the message successfully downloaded need to restart enigma but it's not there when I reboot enigma, tried a couple of times? what could be the issue?
thanks
Ice
Hi Guys
Sorry meant to say TSMedia, clicked the red button to update and then download and it worked thanks.
Also I should have read all the thread regarding the blue colour start up screen
So all seems well at the moment will keep you posted if anything changes
Keep up the good work!
Does anyone know why 1 channel movies doesn't work in TSmedia, it never used to work in my previous 2.1.0 image either
thankz
Ice
Ho installato questa versione sul mio solo2 ora non riesco piu a far funzionare il trr plugin per la gestione della cam. Devo caricare qualche altro plugin?
This is INTERNATIONAL section and third party panels are not supported here. Next time: BAN
Why doesn't media player plugin remembers playback position when reading mkv files i have stored in my NAS ?
Thank you
Black Hole 2.1.1
By Black Hole
  • New skin MX SkyLine SE
  • Add new Crypto systems in OSD: Biss, Bulcrypt, Betacrypt, PowerVu (By Ev0)
  • Add parental control in Bh extra settings panel
  • HbbTV enabled by default for Duo2, Solo2, SoloSE, Ultimo
  • Removed mytube plugin (can be installed from BhSpeedUp)
By Vu+
Kernel:
  • Update Kernel 3.13.5(solo2, duo2, solose)
  • Update Kernel 3.9.6(duo, solo, uno, ultimo)
Drivers:
20140715(duo, solo, duo2, solo2, solose)
20140716(uno, ultimo)
  • - Support SoloSE
  • - Switch to Kernel 3.13.5 (solo2, duo2, solose)
  • - Switch to Kernel 3.9.6 (duo, solo, uno, ultimo)
  • - Fix sound drop in radio channel
  • - Improve PIP (solo2, duo2, solose, Needs E2 update)
  • - Allocate more memory to linux (duo2)
  • - Improve media playback
20140721
  • - Fix vfd problem
Misc:
  • Update r8192cu (4.0.2)
  • Update bridge-utils (1.4 -> 1.5)
  • Set sync PCR at PIP mode.
  • fix duo harddisk detection
  • [hbbtv] fix UI position
  • [hbbtv] upgraded to 'opera-hbbtv_0.2.bb'
  • disabled copy libs to sysroot
  • [hbbtv] reduce CPU usage
  • [hbbtv] fix ipc protocol
  • [hbbtv] fix flickering some channel.
  • support seeking the recorded video
  • lcd4linux: update to 4.1-r2
WARNING! DO NOT USE PERSONAL BACKUP FROM PREVIOUS BLACK HOLE IMAGES, AS THIS WILL MIX KERNELS AND LIBS CAUSING MANY MALFUNCTIONS.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
MERCI BIEN
is not enigma2 file supposed to be protected? or is it open for anyone who wants to build new image??
Dpends by box manufacturer.
Vu+ has it's own open source platform and the source code is freely avaiable. Other brands have it' own work method: closed source or open source.
