Black Hole Vu+ Solo2 2.1.6
I have problem with arabic language written backwards!
And how to put the piccons in the channel list?
Otherwise everything is excellent: beautiful theme and compatible with my Sundtek with DVB-T USB Tuner like 2.1.5 too : I love it! Thanks
In System >> Customise >> Show picons in channel list > yes SAVE
All picons you have for OSD you can use for channel list .Is the same picons.
One more question about picons. What is the correct size of picons? I have uploaded 100X60 but the look small on my tv
Thanks for the continuous development!
Can we restore settings from 2.1.5 after upgrade??? What is the recommended method to do so?
Black Hole 2.1.6
What is new:
  • Support for Picons in channel list
  • New Skin Matrix MX HQ7
  • Add vuplus-tuner-turbo drivers
  • update drivers
    20150302
    - Fix DVB-T tuner detection in new E2 frontend
    - Fix misc bugs.
  • update drivers
    20150317
    - Support new Gstreamer sink interface(OE update will follow)
  • update proxy drivers and utils
    20150318
    - Fix resolution problem when 720P skin is in use
  • update drivers
    20150403
    - Fix problem in new Gstreamer interface
  • update drivers
    20150406(duo, solo, uno, ultimo)
    - Support satip(OE update will follow. Other models are already supported)
  • update drivers 20150511
    - Fix tuner status information
    - Fix loop through(solose v2)
    - Fix Scart(duo2)
  • [hbbtv] support gstreamer-1.0 (1.5.4)
  • Add Cache / CacheEX button
  • Implement gpixmap scale function
  • Add support for picons by name
  • [Animationsetup] change default to simple fade
  • Update languages: Italian, Norwegian
  • fix Dual DVB-T2/C automatic scan problem
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Sorry. Personal Backup found but due to structural changes it is compatibile with the nev image version
