Black Hole Vu+ Solo2 2.1.6
after installing version 2.1.6 Go to the menu plugins and saw that it was possible to adjust the sort of plug-ins and even point script was present. and now I do not see it. where all is lost? upgrade to 2.1.6 fast iptv can not affect?
Many thanks for the image. Time zone of Moscow is incorrect. It is written right (+3) but one hour later actually (+4). I must use Kuwait time (+3) very unfortunately.
First, thanx for the new image!
Sorry. Personal Backup found but due to structural changes it (NOT) is compatible with the new image version
Same happened to me. Anyways,I've installed the new image and configured the box.
But have problems with samba. The server is running, and I can see the shares in the Windows network. But I can not set a samba password.
root@vusolo2:~# smbpasswd -a root
-sh: smbpasswd: not found
I've already installed SWAT. But no connection (boxIP:901) possible.
I have installed BH 2.1.6 on VU+ Solo2
I am trying to use Tuner Server to display content in my PC, but I don't see any virtual channel list that suppose to be created in /media/hdd/tuner.
Any idea about what is happening?
I couldn’t find any info related to this in the portal
Regards
Regards
You have tuner list if you enable tuner in your BOX in /media/hdd/tuner
Of course in this case you use Tuner server only to generate list.
After you can disable.
If you copy this files/ list you can change channels on your PC and use Windows media player .
If you click on a channel in the Tuner list.
Of course you must have a free tuner for that channel and your SAT dish installation needs to support.
You can also use Two types of streaming full and transcoding ,the so-called mobile .
Which type you'll use depends on the box, the speed of the network, PC and other factors.
In transcoding you can change the bit rate, etc.
In Green Panel >>Transcoding Setup you can change port for transcoding.
Which port you can look in Tuner list
normally 8001
I've tested with DUO2 , win 8.1 and it works very well.
Many thanks for your quick answer, but I still need your help to know how enable second tuner in my VU+ Solo2 in /media/hdd/tuner. See attached the screenshot of my tuners setup for reference.
Regards
You have one SAT dish/cable/one LNB
Which means that you can watch only one channel
and at the same time transcode only one channel .(without recording or using PIG at the same time )
When you choose the channel in the TUNER list, the receiver automatically selects a free tuner.
I still need your help to know how enable second tuner in my VU+ Solo2 in /media/hdd/tuner as you are recommending.
Regards
I installed 2.1.6.1 blackhole
And i multiboot with meeboot
But when i restart image doesnt ask me which image should be boot
But old image every time asked me
How can i solve it?
hey all wonder if anybody can help, I run Blackhole 2.1.6 and for some reason I have recently noticed that most of my channels seem to freeze for a few seconds or so
I'm guessing this is down to the internet but I could be wrong, can anybody advice me on what I can disable, enable on the box or to check how well the internet connection is on the box.
also I have my router set so that my vu+ solo2 has a static IP address - so does this mean I can disable DHCP or not on the box
TV channels and Internet are not related... what channels are involved into the issue?
Hi all i have problems whit UPnP-Djmount/mediatomb/mini dlna
I have vu+ soloSEv2 BH2.1.6
If I press blue/blue button scroll down to options: coming on screen message:
" please enable application in BH speed up panel to continue "
So I going to panel scroll down for enable all 3options then red button for Save ,box after reboot box its options again " Disable "
So please what is the problem,thanks for all opinionsa6e0b0eaf5140f18d2c00bd9155db581.jpg
Admin Please move thad to correct Topic for BH2.1.6 solo SE
