Black Hole Vu+ Solo2 2.1.7
Thank you . I have a problem with 2.1.7 After the operation works well but with the private CAM in My H d . Fulbright grants reboot the machine in almost every minute to two minutes and come back to the previous channel . Do you find a solution for me this problem .. Thanks
??????? PRIVATE CAM?????????????????
Radio programs play over the TV UI but I can't stream them over the webif with BH 2.1.7 . TV programs stream fine. Is there a way to fix this? Cheers.
Edit: Radio programs do appear to stream after all. For some reason they start to stream later than TV though - there's a noticeable difference in delay.
both my tuners are set to 28.2 east but I still cannot stream one channel to my computer through openwebif and watch another channel o nthe box
can anybody help
Hi all. Just flashed this image, and I can't see existing subfolders of /media/hdd/movie in the pvr list.
I have to press pvr twice and move through bookmarks, which is quite annoying. In previous versions, I could see folders directly in the list, and navigate through them.
Have you mapped your HDD to /media/hdd folder?
Yesterday i flashed the image and i have problem with tsmedia 10.9.
It doesn't work good and the icons appear awful.
Is there something to do to fix this problem?
Sure! I can see the recording list of the movies I have in hdd/movie, but can't see any subfolder.
If I go through either openwebif or menu -> recordings I do can see the subdirs and access the movies in there, but that's definitely annoying. I want to access them right from the pvr button, just like I could with the BH 2.1.6.
Hi all,
Does anyone know any alternative to the Serienfilm plugin? It no longer works in this BH version, and made quite more friendly the navigation through the recordings.
The PVR list does not show the subfolders of hdd/movie anymore, and I need something to sort & arrange all my recordings.
Thanks a lot in advance!
can someone be kind enough to tell me, how's can I set the ***** on blackhole 2.1.7 for vu + SOLO2 wite view you could bring your image to display
Hello
I updated my solo2 from 2.1.4 to 2.1.7.
Everything is working fine except recording which doesn't work at all.
I am having the same type of error whatever the channel I am trying to record (see attached image)
The paths for recording are correctly set as you can see in the attached screenshot.
The timeshift on the same path works fine
No need to say that everthing was working perfectly on 2.1.4
Anyone can help please. Anything I can look at in the configuration?
Thanks.
