Black Hole Vu+ Solo2 2.1.7
Hello everybody,
I read a lot of questions about users that have exactly the same problem as i have.
Since i flashed with very latest version oh BH on my duo2 ( 2.1.7.01 ) , the second icon
disepear from the webif, i check everything in my receiver , everything seems 2b correctly
setup but nothing appear.
Does any of you guys jave a solution to that matter.
thanks in advance
hello, I flashed the new 2.1.7 image. I put on openmultiboot openatv 5.1 everything went normal, but when I want to reboot openatv grach it is a green screen and it starts on bh.
Envoyé de mon C5303 en utilisant Tapatalk
Hi,
I've just lost the "delete" function in media player in file list while pushing the menu butt on the files as well as "enable move mode" function in bouquet list.
When I push the menu button they are not there anymore...
Can somebody tell me how to restore them without reflashing.
It happened to me 2 times before when I was on another BH versions. But I had to reflash the reciever.
Currently Im on 2.1.7 solo2
Thanks
Black Hole 2.1.7 MultiBoot
WHAT IS NEW
  • New switch from MeoBoot to OpenMultiBoot to use different kernels and drivers for each installed image.
  • New skin MX i6p By Matrix10
  • Vu+ drivers 20150623
    - Fix tuning problem(AVL6211, duo2, solose)
    - Improve vtuner(satip support)
    - Fix scrambling bit in recording
    - Improve transcoding
  • Xbmc Support 576/720/1080 resolution
  • Updated Vuplus-Blindscan
  • Updated HbbTv
  • Updated WebManual
  • Added Sat>Ip Client
  • Included UiPositionSetup
  • Removed MeoBoot
  • Added OpenMultiBoot
  • Updated Lcd4Linux
  • Updated MediaTree (usb tuners drivers)
  • Fixed random socket error
  • [ScanSetup] fixed error on complete scan with T2 tuners
  • [ScanSetup] fixed TT3L10 automatic scan problem
  • [unicable] support JESS(EN50607) and update unicable.xml
  • AnimationSetup: set default to animations disabled
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
graziee
Hi Guys,
Ive a really strange problem. I hope someone knows how to solve it.
Ive installed BH 2.1.7 and configured my tuner.
Ive DiseqC ABCD with 3 LNBs
I updated then my Bouqet (also satelites.xml ) and uploaded again.
since there Im missing one of my satellites.
if i open tuner config and want to put Eutelsat 7 on port C, it shows me only 2 existing satellites.
hotbird and astra, nothing else, i cant choose any other satelite!?
has someone an idea before I try to repeat installation!?
Thanks in advance
