Black Hole Vu+ Solo2 2.1.7
Hi,
I got a problem. after flashing the latest 2.1.7 on the Solo2 wont initialise any hardrive.
Its also not possible to check the file system. I always get a green screen :(
kind regards
Hi,
kind regards
Update default skin from Black Hole image server .
green>>yellow>>addons download manager>>BH image skins>>Skindefault BH 2.1.7
1) - You have to download Halus61 picons here --> http://www.vuplus-community.net/boa...lack-hole-team-only.19655/page-16#post-179781
or
2) - Download it from addons server, by pressing on your RCU ( Remote control unity ) <GREEN> <YELLOW> and install it
For not filling your flash memory, you must use an USB pen drive mapped as /media/usb
3) - If downloaded from the feeds inside /media/usb ... it will create a directory inside /media/usb/ as /media/usb/picon where the system put the " png " picon files.
If you use the 1) - condition you you must map your USB pen drive as /media/usb and create under /media/usb the picon directory.
Upload the picon files download to /media/usb/picon on using an FTP tool like, Dreambox Control Center, Filezilla, WinScp or other FTP tool at your desire!
To have picons displayed on channel list you must go to User Interface on setup menu and apply SHOW PICONS ON CHANNEL LIST changing it from <no> to <yes>.
Detailis on how to do it: Menu > Setup > System > Customize > Show picons in channel list: Yes
