Black Hole Vu+ Solo2 2.1.7
Hi, everybody ,I'm sorry to say this and I excuse me, in advance before the administrator and the Blackhole developers, but I have to say this:
These latest images are bad, and we cannot compare with the old images, they were strong and not too complicated, nowadays this images are full of , excuse me the word, crap and they don't work steadily as before they have plenty of bugs ,the more you change the more the image is spoiled, I don't understand people saying this is a great image ,I don't see were is greatness.
I installed today this image, because since 213 I changed to another team image, and I thought maybe now the image is good ,but no, it is worse ,if it is possible.
I could't make it work properly with my VU+SOLO 2 and I gave up and finally uninstalled the "thing".
If you allow me I will only number a few of the bugs I found:
a) Meoboot doesn't work anymore as before.
b) Epg doesn't work properly and hard to discover how to make it work
c) Plugins not easy to find
d) You cannot know how much you have watched films recorded, there is nothing to guide were you left the film you watched so that you know what you have watched already, it's a blind thing, my actual image has it all, even with colors corresponding to the records you have not watched, those you din't, and those you have watched some part of it, even a color for what you are recording in the moment.
e) You cannot watch a channel while recording another one, unless same frequency.~
f) Very sad colors or no colors at all on GUI everything is sad and black, You can name it Blackhole but put some joy on it.
g) Very litle default font text letters, you cannot see a thing unless you have very good and young eyes, horrible...
I will stop now because I had more to add , but I stop because it's fastidious, to keep reading me there are lots more
To finish I will say ,allow me and don't take it bad, you can do better, don't forget ,sometimes , not to say always, make simple and nice it's better than too complicated and ugly, I hope you guys will find a way to do a beautiful Blackhole image nice and simple, above all for the great pleasure of users, working 100%.
Good luck for all and again thank you for your hardworking, keep going...
a) MeoBoot has REMOVED. Do you refer to OpenMultiboot? It's ANOTHER PLUGIN DIFFERENT THAN MEOBOOT.
b) Read a lots of tutorials in this Board and web about setting up EPG correctly
c) Not easy? GREEN button ... it's so easy ....
d) it's not clear what you mean, sorry
e) FALSE. If the box is setup correctly and you have correct hardware to see two INDIPENDENT channels, the problem is into some third-party software YOU HAVE installed into your box so called EMULATORS. So not bother us about that.
f) it's not clear. Please post some examples
g) the "issue" is related to HD skins (1920x1080 pixels) that makes font smaller....
Your image is bad and ugly to the view and with lots of bugs, and too complicated to use, sorry, you don't appreciate to hear this ,everybody uses emulators and I don't touch any setup to my actual image to watch channels while recording and I, just to finish, will say another thing ,you have to set up usb pen , which is not automatically mounted, in my image Usb pens are automatically detected and properly mounted and running 100%, I will not reply to any other posts the matter is closed for me, good luck, you have to read a full manual to set up correctly your image to work 80%, even so....
If you have unhappy with BH image, don't use it.
About EMUs, you haven't read our Board rules .... and I'm very disappointed about it.
No emu tolerated here.
If everyone does something wrong, you follow them?
Ηι after updating to 217 i lost the transcoding icon on webif.I reflashed the image but the problem remains.
Anyone who can help please?
The same here. I checked the setting for transcoding and Webif and all seems OK like in BH 216. But when opening the webif in browser there is only the possibity to stream without transcoding.
I would also appreciate help from the experts, please.
Many thanks.
Black Hole 2.1.7 MultiBoot
WHAT IS NEW
  • New switch from MeoBoot to OpenMultiBoot to use different kernels and drivers for each installed image.
  • New skin MX i6p By Matrix10
  • Vu+ drivers 20150623
    - Fix tuning problem(AVL6211, duo2, solose)
    - Improve vtuner(satip support)
    - Fix scrambling bit in recording
    - Improve transcoding
  • Xbmc Support 576/720/1080 resolution
  • Updated Vuplus-Blindscan
  • Updated HbbTv
  • Updated WebManual
  • Added Sat>Ip Client
  • Included UiPositionSetup
  • Removed MeoBoot
  • Added OpenMultiBoot
  • Updated Lcd4Linux
  • Updated MediaTree (usb tuners drivers)
  • Fixed random socket error
  • [ScanSetup] fixed error on complete scan with T2 tuners
  • [ScanSetup] fixed TT3L10 automatic scan problem
  • [unicable] support JESS(EN50607) and update unicable.xml
  • AnimationSetup: set default to animations disabled
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Thank you.
Hello,
I've update to 2.1.7 have a solution to my problem but this is not the case.
I can't watch another encrypted channel when recording.
Do you have a solution?
Thx
pJ
Many thanks.
Me too, same issue transcoding icon not available in webif.
I have faced the same problem as I upgraded to 2.1.7, there is no transcoding option on the WebIf and also it doesn't stream through my iPad using VU+ PlayerHD.
any help will be appreciated.
