Black Hole Vu+ Solo2 2.1.7
Hi,
has someone tried the satip client ?
I did and I have a choppy sound plus laggy video.
If i do pause and play, to play out of a buffer, it is fine.
Thanks
Black Hole 2.1.7 MultiBoot
WHAT IS NEW
  • New switch from MeoBoot to OpenMultiBoot to use different kernels and drivers for each installed image.
  • New skin MX i6p By Matrix10
  • Vu+ drivers 20150623
    - Fix tuning problem(AVL6211, duo2, solose)
    - Improve vtuner(satip support)
    - Fix scrambling bit in recording
    - Improve transcoding
  • Xbmc Support 576/720/1080 resolution
  • Updated Vuplus-Blindscan
  • Updated HbbTv
  • Updated WebManual
  • Added Sat>Ip Client
  • Included UiPositionSetup
  • Removed MeoBoot
  • Added OpenMultiBoot
  • Updated Lcd4Linux
  • Updated MediaTree (usb tuners drivers)
  • Fixed random socket error
  • [ScanSetup] fixed error on complete scan with T2 tuners
  • [ScanSetup] fixed TT3L10 automatic scan problem
  • [unicable] support JESS(EN50607) and update unicable.xml
  • AnimationSetup: set default to animations disabled
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Hi! Thx for sharing this image!
I had installed version 2.0.5 prior to 2.1.7.
My DVB stick, Hauppage wintv PCstick, was working ok. Now, image is freezing like each second and sound is also cutting for tenths of seconds.
Has something changed on the support of this DVB stick?
Thanks in advance.
I have problems with install external hdd in this Image
This is problem
update from 2.1.5 to 2.1.7 not working
i used the identical usbstick (SanDisk Cruzer Blade 32GB) from which i used to Update to 2.1.5 - (which worked fine back then, so i don't think the usbstick is the issue)
i removed the old vuplus folder on the usbstick and extracted the 2.1.7 zip provided here for the solo2
all steps during update seem to work just fine (front usbport) - but in the end, it just boots into 2.1.5, which you can tell immediately by still using the bright blue bootlogo... and is confirmed when entering the menu/information/about settings... still says 2.1.5
i tried 3 other (older usbsticks with diffrent sizes 8GB/4GB) - same result... installations appears to progress just fine, in the end it counts down from 10 to 0 and reboots to 2.1.5 again
i don't know where to go from here :/
Are you formatting the usb stick to fat32 first before copying the vuplus folder over to it??
Sent from my iPhone 6 using Tapatalk Pro
Thanks in advance.
Same here.
NOVA-T USB stick, green screen.
Open multiboot not working.
Too many errors.
Thanks to the team for this nice image
Everything is working fine, but it seems that there is an issue when using a common interface.. in fact I have an Irdeto secure SMARDTV cam for My HD channels on 7°W and 26°E, witch is working fine with previous images (2.1.4), But with this last image, and when watching my hd channels, enigma2 restarts after 2 or 3 minutes. This happens only when watching my hd channels, no problem when watching fta or other encrypted channels.
Thanks for taking a look.
