Black Hole Vu+ Solo2 2.1.7
Thanks BH team. Great firmware.
Only one small thing, I think that the video quality is lower with 1.7 than with 1.6.1.
Driver problem?
Please advice.
Black Hole 2.1.7 MultiBoot
WHAT IS NEW
  • New switch from MeoBoot to OpenMultiBoot to use different kernels and drivers for each installed image.
  • New skin MX i6p By Matrix10
  • Vu+ drivers 20150623
    - Fix tuning problem(AVL6211, duo2, solose)
    - Improve vtuner(satip support)
    - Fix scrambling bit in recording
    - Improve transcoding
  • Xbmc Support 576/720/1080 resolution
  • Updated Vuplus-Blindscan
  • Updated HbbTv
  • Updated WebManual
  • Added Sat>Ip Client
  • Included UiPositionSetup
  • Removed MeoBoot
  • Added OpenMultiBoot
  • Updated Lcd4Linux
  • Updated MediaTree (usb tuners drivers)
  • Fixed random socket error
  • [ScanSetup] fixed error on complete scan with T2 tuners
  • [ScanSetup] fixed TT3L10 automatic scan problem
  • [unicable] support JESS(EN50607) and update unicable.xml
  • AnimationSetup: set default to animations disabled
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Very grateful to the entire staff.
Using Solo2 with BH 2.1.7 in Flash, I put a different Image in Multiboot and everything seemed OK
until I tried to boot back into the Flash Image and the Receiver hung during the "booting" stage.
Then switched off and on from the Mains and got the Flash Image back.
Is this how it is supposed to work or have I done something wrong ?
Thanks.
Thanks.
Of course not,
The problem is that some USB sticks are doing very badly in combination with the receiver.
I have older USB sticks max 4Gb and all work great.
I bought two new 8 Gb not one is working properly.
If you have older and smaller sticks , try it.
Next time if you have problem disconnect USB stick and try to boot flash image.
i have problem with images in openmultiboot.
OpenBlackhole can't start, BlackHole2.1.7 in OMB work ok, but when i try restart gui or deep stanby i have GS. VTi in OMB also can't restart or deep standby.
Hi,
Please, BH Team,
DLNA server is not working with this release. I can install and start it but Vu+Solo2 does not appear on my devices.
Need help please!
Boot image has not changed in vu Plus solo 2 after update to 2.1.7 by USB.
vu-new-release217-png-11862-png.22210
