Black Hole Vu+ Solo2 2.1.7
Great Job BH Team . Would like to ask if some1 can explain the function of sat> ip client.
Any toturial will be apreciated.thanx
Black Hole 2.1.7 MultiBoot
WHAT IS NEW
  • New switch from MeoBoot to OpenMultiBoot to use different kernels and drivers for each installed image.
  • New skin MX i6p By Matrix10
  • Vu+ drivers 20150623
    - Fix tuning problem(AVL6211, duo2, solose)
    - Improve vtuner(satip support)
    - Fix scrambling bit in recording
    - Improve transcoding
  • Xbmc Support 576/720/1080 resolution
  • Updated Vuplus-Blindscan
  • Updated HbbTv
  • Updated WebManual
  • Added Sat>Ip Client
  • Included UiPositionSetup
  • Removed MeoBoot
  • Added OpenMultiBoot
  • Updated Lcd4Linux
  • Updated MediaTree (usb tuners drivers)
  • Fixed random socket error
  • [ScanSetup] fixed error on complete scan with T2 tuners
  • [ScanSetup] fixed TT3L10 automatic scan problem
  • [unicable] support JESS(EN50607) and update unicable.xml
  • AnimationSetup: set default to animations disabled
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Ci module still a masive problem getting crash green screen after restart with ci module inserted. Same thing hapend since 2.1.6 and 2.1.6.1. Not been there before that. I have already sent email to vu website but sims not to have been read or ignored. Very let down. Need the use of this ci module. What is going on ?
SKIN DEFAULT BUG FIX HDD Initialisation Panel BH 2.1.7
DOWNLOAD SKIN FROM BH image server >> Skins>> SKIN DEFAULT BH 2.1.7 (BUG FIX HDD Initialisation)
hi
tnx for new 2.1.7 software
after install my screen in not set and not fit. the menu i wierd and screen not fit. i have the same setting .1080p just scale.?!!?!
hi
to adjust the position of the screen image and the skin,use a plugin UI position setup in Green Panel
