Black Hole Vu+ Solo2 v.2.0.0 OE 2
Great job! But I have a problem with the wifi usb BH in this version 2.0. Previously, my usb wifi-VU + worked perfectly in all previous versions of BH. Please urgent help.
I did configure the WLAN. I think it's working, but it did not. I did a test network. and found out that I have a wlan adapter: wireless ok ok, DHCP enabled, IP address: unconfirmed, nameserver: unconfirmed. And that's why I do not have internet on my vu + solo2. Please urgent help.
Was that with the assistant on the first boot after you've installed the new image?
If so, just do it again and it will work because you did not save it.
This time do throught the menu >> setup >> system >> Wireless LAN setup
it should work again.
So I did the first start-up. Now I tried again but still the same problem.proszę for urgent help.
On latest bh 2.0.0 image on my solo2 using cable connection ok (not tried wireless connection) wireless connection on ultimo ok on duo wireless connection not working so I have go back to bh 1.7.9 images on my dou to connect wirelessly
