Black Hole Vu+ Solo2 v.2.0.0 OE 2
So I did the first start-up. Now I tried again but still the same problem.proszę for urgent help.
DHCP works without problems
After changes save and restart image .
If you use a fixed IP address and you have problems
First put on the DHCP
restart
change the DHCP to FIX IP Adress
Check nameserver
Maybe you need to manually enter it
Save and
restart
I have the same problem with time, it shows 2 hours early. Except for that i like the image and the new skin from Matrix.
On latest bh 2.0.0 image on my solo2 using cable connection ok (not tried wireless connection) wireless connection on ultimo ok on duo wireless connection not working so I have go back to bh 1.7.9 images on my dou to connect wirelessly
I'm using Wireless connection on solo2 I confirm it works like charm.
Did you manage to put the right time zone in:
Menu >> Setup >> System >> Timezone
I have done it and it now it is ok.
restart
Check nameserver
Save and
restart
I made it but i have the same problem.Pleace help.On BH 1.7.9 I have not problem with Wifi usb.Pleace help.
I am back here with a Solo 2. Finally it's possible to update the image online...no more flashes!:yahoo:
All I need now is a working Blackshadow3 skin...
try this solution:
In your router change the encrypt to WPA and use 10 digits as code.
In your solo2 wireless setup be sure to chose WPA as encrypt mode then don't forget to chose the right ESSID (name of your router connection).
Good luck.
Why isn´t the option of modul kernel:
ExportFS Module Needed For NFS-Server
NFSD Module Needed For NFS-Server:fie:
