Black Hole Vu+ Solo2 v.2.0.0 OE 2
Hi, I have only issue so far.
All the channels in "ALL" channels list is coming up twice. I scanned the satellite and used the option to clear the previous scans but it didn't work.
Please help...
Solo2 on E2.0.
Why you don't use DreamBox Edit ?
You don't need to do a scan every time you change your image on the VU+
I'm using Dreambox Edit, I have 927 channels which got duplicates and I don't fancy deleting em one by one!
A little explanation if this is the cause of your problem
and maybe there's someone else.
Have you use
Green Button >> yellow button >> Settings Feeds Online update
Do yo have there installed settings.
If you do not want to have automatic update settings from the image server
remove Settings .Green button Remove
Upload/FTP/dreamoxedit e.t.c or Scan settings again.
RESTART Enigma2 or RESTART image.
i have 100% cpu usage on new BH (today i do online update).
This same problem i have on new VTi
On opli everything is ok
anybody can configm ?
top command in telnet
OK here is TOP
Where are there you see these 100% I do not see ??
root@vusolo2:~# top
top - 23:42:52 up 41 min, 1 user, load average: 0.01, 0.06, 0.11
Tasks: 94 total, 1 running, 93 sleeping, 0 stopped, 0 zombie
Cpu(s): 0.7%us, 0.5%sy, 0.0%ni, 98.8%id, 0.0%wa, 0.0%hi, 0.0%si, 0.0%st
Mem: 571856k total, 156848k used, 415008k free, 432k buffers
Swap: 0k total, 0k used, 0k free, 65632k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
1514 root 20 0 99.3m 42m 8856 S 1 7.6 0:37.00 enigma2
544 root 20 0 0 0 0 S 1 0.0 0:04.06 RTKTHREAD
1550 root 20 0 57512 22m 11m S 0 4.0 0:04.24 hbbtv.app
2368 root 20 0 2656 1128 912 R 0 0.2 0:00.03 top
1 root 20 0 1780 624 548 S 0 0.1 0:01.12 init
2 root 20 0 0 0 0 S 0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0 0.0 0:03.27 ksoftirqd/0
5 root 20 0 0 0 0 S 0 0.0 0:00.00 kworker/u:0
6 root RT 0 0 0 0 S 0 0.0 0:00.00 migration/0
7 root RT 0 0 0 0 S 0 0.0 0:00.00 migration/1
9 root 20 0 0 0 0 S 0 0.0 0:01.01 ksoftirqd/1
11 root 0 -20 0 0 0 S 0 0.0 0:00.00 khelper
12 root 20 0 0 0 0 S 0 0.0 0:00.00 kdevtmpfs
13 root 20 0 0 0 0 S 0 0.0 0:00.00 sync_supers
14 root 20 0 0 0 0 S 0 0.0 0:00.00 bdi-default
15 root 0 -20 0 0 0 S 0 0.0 0:00.00 kblockd
16 root 0 -20 0 0 0 S 0 0.0 0:00.00 ata_sff
17 root 20 0 0 0 0 S 0 0.0 0:00.03 khubd
18 root 0 -20 0 0 0 S 0 0.0 0:00.00 cfg80211
19 root 0 -20 0 0 0 S 0 0.0 0:00.00 rpciod
20 root 20 0 0 0 0 S 0 0.0 0:00.00 kswapd0
21 root 20 0 0 0 0 S 0 0.0 0:00.14 kworker/1:1
22 root 20 0 0 0 0 S 0 0.0 0:00.00 fsnotify_mark
23 root 0 -20 0 0 0 S 0 0.0 0:00.00 unionfs_siod
24 root 0 -20 0 0 0 S 0 0.0 0:00.00 nfsiod
25 root 0 -20 0 0 0 S 0 0.0 0:00.00 crypto
35 root 20 0 0 0 0 S 0 0.0 0:00.00 scsi_eh_0
36 root 20 0 0 0 0 S 0 0.0 0:00.00 scsi_eh_1
37 root 20 0 0 0 0 S 0 0.0 0:00.03 kworker/u:1
39 root 20 0 0 0 0 S 0 0.0 0:00.00 scsi_eh_2
root@vusolo2:~#
OK here is TOP
my top
Tasks: 100 total,   2 running,  98 sleeping,   0 stopped,   0 zombie
Cpu(s): 14.0%us, 37.0%sy,  0.2%ni, 46.3%id,  0.0%wa,  0.0%hi,  2.5%si,  0.0%st
Mem:    571856k total,   146852k used,   425004k free,     1260k buffers
Swap:   500732k total,        0k used,   500732k free,    55752k cached
 1006 root      20   0 98.5m  41m 8844 R   99  7.5   1:47.61 enigma2
 1074 root      20   0 57512  22m  11m S    5  4.0   0:06.68 hbbtv.app
 1152 root      20   0  2548 1132  912 R    1  0.2   0:00.22 top
my top
I do not know what are you doing with the image
but this is clearly not classical BH image in work.
My processor is tired of not working :D
root@vusolo2:~# iostat
Linux 3.3.6-1.2 (vusolo2) 02/17/13 _mips_ (2 CPU)
avg-cpu: %user %nice %system %iowait %steal %idle
1.61 0.01 1.90 0.01 0.00 96.47
13.70 0.07 39.17 0.64 0.00 46.41
Once again your problem with CPU usage is something else and not the BH image.
I see You use SWAP
SOLO2 not need SWAP .
I have 70% FREE RAM with Full operational image.
CPU very low
I really do not know what you did with the image.
Install and test again when the image is clean.
Here I just see two issues:
1) Acessing Plugins from Menu (Menu button and not from Green Button) crashes the Solo2, leading it to a green screen.
2) VFD is showing channel names in uppercase letters. I mean, if the channel name is "Nat Geo", when we scroll over the channel list we get "Nat Geo" on VFD, but if we stay on that channel, then will appear "NAT GEO" on VFD when should be (and always had in previous versions of BH) "Nat Geo".
Regarding subtitles on Media Player, is bad like previous versions. I was hoping some improvements due OE2.0 version, but no... Some lines of subtitles are missing, letter size is small and position isnt good either. I hope someone from BH team say me something about that, because I've asked about it N times before...
Best Regards
Nobody checked these problems I mentioned?
Regards
Regards
NO problems with Plugins .See pic.
names in uppercase >>
It depends on the information from the transponder
If you're using satellite EPG NOW / NEXT
If you're using a net EPG, EPG you have download from NET
depends from NOW/NEXT DATA in EPG and from config for EPG in the EPG panel
where it can be configured NET or satellite EPG. (EIT EPG config)
So no special BUG for "Nat Geo",
If it was a bug in the image
He would reflect on all channels
evident difference NatGeo from Sky Ita and Canal + Spain
So not a bug in the image, but the information from satellite
I see You use SWAP
CPU very low
use meoboot, install image (i use vti5.1) and boot this image in meoboot, then check cpu usage, after this boot from flash and also check cpu usage
use meoboot, install image and boot this image in meoboot, then check cpu usage
This image is not intended for MeoBoot but for the flash.
Totally not interesting to me.
BH image is a flash image.
PLEASE NOTE:
This image is not compatible with previous skin versions.
This image is not compatible with previous OE 1.6 plugins.
This image is not compatable with any previous Personal Backups you have made.
YOU MUST install this as a fresh image, restoring from a previous backup will corrupt the image and make it very unstable. You also will need to check for and remove any vuplus folders found on your hdd or usb devices before you install this image.
