Black Hole Vu+ Solo2 v.2.0.0 OE 2
ok, instal BH in meo.......also not intended for meo?
so why is this plugin ?
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.​
The image MUST be installed in flash.​
Black Hole does not support images not installed in flash​
So NEXT TIME PLEASE READ INFO ABOUT IMAGE ON PAGE 1​
ok understand, but my question is still actual....
if i can't install image in meo (vti) so why is plugin meoboot ?
With this plugin you can test any other image on USB
if possible.
And is intended only as a test possibility.
But it does not guarantee 100% working .
So this plugin is part of BH image and BH image is not multiboot (USB) image.
If you like to install USB plugins e.t.c you can use BH Universe possibility.
evident difference NatGeo from Sky Ita and Canal + Spain
So not a bug in the image, but the information from satellite
You didnt understood what I said!
I was talking about VFD display!!
For example, when you are on NationalGeo HD on Sky IT should appear "NationalGeo HD" on VFD but appear "NATIONALGEO HD".
Understood? :)
Understood? :)
NO ,
NOT ON SKY ITA.NOT in my Solo2 with BH image and My skin
Im using in this moment.
Channel name is the same in Channel list and VFD.
NO ,
Channel info is the same in Channel list and VFD.
I'm using original skin and it's how works here...
When I select channel on channels list, it's all OK. But when I choose a channel, all letters are Up-cased on VFD Display. Maybe I need to update to today's update...
Also I have just one more thing that bothers me in this perfect image, if you can help me please let me know. It's this: how can I change subtitle position and size on Media Player?? It's possible on OpenPLI but on BH I cant find any option... is it possible, right?
I have test now with default skin and VFD is OK.
Maybe you installed something in the image
Perhaps LCD Picon, some plugin or similar.
LCD picon can not be used in solo2.
I think that you can not change subtitle position and size in Media Player
but I do not use , so I'm not sure if there is another possibility.
Goodnight, my bedtime .
Oh! I have LCD4Linux installed indeed... I have to test it without it. Anyway, with previous version I had no problems with LCD4Linux indeed. But now, since BH are using OE2.0 I've installed mips32 version. Maybe that's the reason.
About subtitles, is really a shame... I hope someone can help me on that.
Thanks
Morning! Somebody get same problem like me.. Try to play a mkv file on Media Player, but on screen it show streached faces...
if possible.
ok, understand...
this image (vti) is incompatible with moeboot, i removed it. Removed also meoboot according to help from this plugin, restart box, and i have still high cpu usage. Only new flashing solved problem....
swap is deactivated. Pure image.
IMO this is a bug.
Thanks for your work!
Matrix10 could you bring back the MX HC Hi color skins that were my favourite and not compatible any more? :(
ok, understand...
IMO this is a bug.
I have no other choice :D
but to say that you are right,and thanks for good testing and info.
But I am not a specialist in this
I have informed coder
let's wait for his opinion.
Until then, I suggest that you do not activate and use MeoBoot
in your image.USE ONLY BH Flash image.
anyone else having problems with skins? when I flash image and use original skin all is OK! but the minute I download and install another Skin i lose the channel names in the display screen.
All 4 OE2.0 skins in the addons server do that to my box
regards
Hi all!
Great work with new BH, just that i am having little problem with fancontrol2 plugin. When monitoring fan , i dont get any info about curent tmp, or rpm or voltage.
Dont know if fan is on or not :x, Anyone have similar problem?
Hello everyone.
Just to update you about my early post.
1) "Problem" regarding VFD letters was caused about some option in some plugin I'm using. With that option off, all is great like Matrix10 said (thanks to him about this). So, this is OK :)
2) About subtitles, I manage to install Font Magnifier from BH server and now I can manage any subtitles (from TXT, Media Player, etc..) as I want! Thats so GREAT!! :D
Just a little little question about that: is Font Magnifier able to move subtitles on screen too or I need other plugin/form to do that? :)
So now I can say ALL IS PERFECT FOR ME :)
I've tried many mkv's since yesterday and no problems in any of them! Also I've managed .ts, .iso (with DVD plugin) and some audio files. All 100% OK :)
Hi all!
All OK here about that too. I can see that info, like I saw in previous versions of BH :)
Also... another question regarding that. Which is the ideal Temperature for Solo2? Mine is working around 37ºC/41ºC, when I have my fireplace ON. Thats a good value or should be less? I have my fan in 1890rpm (I think, I cant remember exactly).
Hm, ok wierd cos i dont c curent value but when i do test i cant hear on max it and it shows results "ok"
My curent tmp is 41ºC , and no rmp ../monitor/
Cant you see the temperature by BH menu? I can see it from there :)
