Black Hole Vu+ Solo2 v.2.0.8
OK looking at the screenshots from the first post it does seem the skin is actually the correct one. Is there any way I can get the skin from 2.0.7 back on as I do really think this skin is a step backwards.
I am not professional on this but 2 things I would advise you and I make sure I always do b4 install new image. I disconnect the internal hdd prior updating and second thing make sure you use a decent usb flash drive (I always have ready 2 usb's in case anything goes wrong .
It depends, maybe for you,
but is true is good very fast skin .
I use one for two hours and the second two other hours.
Every time someone asks for older default skin :D
But I have put the old skin on our image server
There, you can download it MX S skin for BH 2.0.8
Every time someone asks for older deafult skin :D
many thanks matrix a much better skin
rg tm
Many thanks Maxtrix10, love that skin - thank you for all your hard work I appreciate it.
Black Hole 2.0.8​
What is new:​
  • New Vu+ drivers 16 december 2013
  • New Skin MX SkyLine By Matrix10
  • New Bootlogo IOS 7 Style by mikark
  • Support wmv, wma, asf media file (duo, solo and uno have to be enabled in BhSpeedUp)
  • Update OpenWebIf
  • BhEpgPanel: Change internal openepg default channel to Nat Geo
  • Update languages fr, no, sv
  • Add Audio Effect Plugin
  • Transcoding : support multiple encoders
  • Transcoding : support resolution setting , and advanced setup
  • A/V settings : update.
    - add "AAC downmix" setup
    - fix entry name, Dolby Digital downmix -> Dolby Digital / DTS downmix
  • gstreamer plugins updated:
    - added support for mms protocol.
    - added patch related on rtsp.
  • Transtreamproxy updated.
  • Support more video codecs in media playback.(OE 2.1 gstreamer)
  • Reduce First picture display time(zapping time improvement : duo2, solo2)
  • Support dual transcoding(duo2, Only 2nd transcoding is mutually exclusive with PIP)
  • Improve PCM playback(solo, duo, uno, ulitmo)
  • Support 3D surround (solo, duo, solo2, duo2)
  • Support AVL(automatic volume leveler)(duo2, solo2)
  • Support more proc entries to control duo2 transcoding.(Plugin will follow)
  • Improve temperature control of dual tuner when not in use(duo2, uno, ultimo)
  • FPGA update in solo2(done automatically in the first bootup after installation)
  • Fix EOS deteciton in media(PCM) & TS playback
  • Support AAC passthrough
  • Remove unnecessary debug messages(duo2)
01-bootlogo-jpg.13970
shot3-jpg.13972
shot4-jpg.13973
shot5-jpg.13974
shot7-jpg.13975
shot11-jpg.13976
shot12-jpg.13977
shot13-jpg.13978
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Merci de ... bon travail. Installé sans problème. seulement s'il vous plaît mettre à jour également le premier logo Blackhole comme Bootlogos nouveau style de ios7 ....
Thanks a lot for this great job.
I have one question?
When i did restore personal seting is returnet okd bootloge
I want to rist the new bootloge ios 7
Thenks
Not tested yet, but I hope that new gstreamer will fix the problem with not working .srt subtitles in Media Player.
Anyway... good job as usual...
Thank's good job. Installed without problems but when I install the HDglass skin (7.92) and use any colored button ( blue or yellow or green) i got green screen error.
Is this version of bh compatible with hd glass skin ?
Thanks's again.
