Black Hole Vu+ Solo2 v.2.0.8
Installl new versión HDGlass 8. It Works great without Green screen.
Thank's good job. Installed without problems but when I install the HDglass skin (7.92) and use any colored button ( blue or yellow or green) i got green screen error.
Is this version of bh compatible with hd glass skin ?
Thanks's again.
You can't update online to this image version, you need to do it by an usb stick.
Thanks Mito, I've unzip the image to usb stick and stick it on the front of the box. Started the box and nothing happened. May I know if there is a guide on how to do this as I couldn't find it with a search.
I'm updating from 2.0.5 btw.
Appreciate it, thanks.
Warning ...
My suggestion is to read the forum rules
before I'm forced to give BAN.
dear matrix thanks a lot for the warning i'm new to the black hole community and yur the best in the industry so i just needed help on this ***** problem and thought you might be able to help wasn't sure if ***** was some reference that i shouldn't have mentioned any ways you didi a great job with this new image thanks a lot ....
Dear Blach Hole Teeam: The new update is wonderful as always, but because I use my vu+solo2 to watch live internet streams, I am afraid to say that this image does not play all "rtmp" streams. A good example is when I put only the rtmp link and then the playpath separated with a slasth without writing the playpath=, swfUrl=, and PageUrl= , as is the case with this example "rtmp://72.55.164.21/live/livestream" . I have another remark that I would like to stress here: sometimes in the old version, when an internet stream is played by the Solo2, I acccidentaly touch the right side of the round botton (it should usually wind a stream forward), but this did not happen. Insead, the receiver jammes up. Now and thanks to your wonderful work, it goes to the second channel if the the stream I am playling is an http streams If the stream is rtmp, then the receiver freezes and I should turn it off, using the switch botton because the receiver does not respond to the remote control any more. My hope is that you put in consideration updating the rtmp link player when you are updating the image. I also hope that you consider creating a kill-task-botton. This would make it a lot easier in case the receiver is jammed up or frozen. Thanks in advance and I hope that I am posting this in the right place without making any violation.
I have vu+solo2
Update succesful!!!
trancoding working even via mobile phone!!!! cool. now wherever I am I can see my channels.
I have just one question: in the setup of transociding I dont see the panle as shown in the first post, but I can just configure few things (bitrete, port, fps). Is it normal?
How can I access the advance setup options shonw in the first post?
thanks inadvance
and thanks also for the great JOB!!!!!
I have vu+solo2
Update succesful!!!
thanks inadvance
I think it's normaal because some features are only for Duo2 box
Black Hole 2.0.8​
What is new:​
  • New Vu+ drivers 16 december 2013
  • New Skin MX SkyLine By Matrix10
  • New Bootlogo IOS 7 Style by mikark
  • Support wmv, wma, asf media file (duo, solo and uno have to be enabled in BhSpeedUp)
  • Update OpenWebIf
  • BhEpgPanel: Change internal openepg default channel to Nat Geo
  • Update languages fr, no, sv
  • Add Audio Effect Plugin
  • Transcoding : support multiple encoders
  • Transcoding : support resolution setting , and advanced setup
  • A/V settings : update.
    - add "AAC downmix" setup
    - fix entry name, Dolby Digital downmix -> Dolby Digital / DTS downmix
  • gstreamer plugins updated:
    - added support for mms protocol.
    - added patch related on rtsp.
  • Transtreamproxy updated.
  • Support more video codecs in media playback.(OE 2.1 gstreamer)
  • Reduce First picture display time(zapping time improvement : duo2, solo2)
  • Support dual transcoding(duo2, Only 2nd transcoding is mutually exclusive with PIP)
  • Improve PCM playback(solo, duo, uno, ulitmo)
  • Support 3D surround (solo, duo, solo2, duo2)
  • Support AVL(automatic volume leveler)(duo2, solo2)
  • Support more proc entries to control duo2 transcoding.(Plugin will follow)
  • Improve temperature control of dual tuner when not in use(duo2, uno, ultimo)
  • FPGA update in solo2(done automatically in the first bootup after installation)
  • Fix EOS deteciton in media(PCM) & TS playback
  • Support AAC passthrough
  • Remove unnecessary debug messages(duo2)
01-bootlogo-jpg.13970
shot3-jpg.13972
shot4-jpg.13973
shot5-jpg.13974
shot7-jpg.13975
shot11-jpg.13976
shot12-jpg.13977
shot13-jpg.13978
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Thanx a MILLION
