Black Hole Vu+ Solo2 v.2.0.8
The front display only shows time now. Before it showed date and time
Is it possible to display date and time again?
Hello,
Good Job!
anyone knows possible options for the command: /usr/bin/Blackholecmd ?
Is there an option to reload blacklist/whitelist in command line (equivalent to the reload from parental control meu)?
I want to switch the blacklist from time to time with a cron job, and just copying the file doesn't do the job.
Wondering if there is a kind o option reloadserrtings ...
Thanks.
Updated to B.H 2.0.8 on VU+ Solo2 without any issues. I must say it's wonderful and thanks to B.H team for all your hard work.
Just upgraded to 2.0.8, but the support of mkv with embedded subs track still remain minimal.
I'm able to see only the default subs track, no way to choose between forced/english/french and other subs tracks available in the muxed mkv file.
hi tried to put this new image on my vu solo 2 get as far as blackhole speedup retriveing data and gets stuck any ideas thanks
Hello,
Good Job!
Thanks.
BH commands
standby shutdown reboot restartenigma2
Test this i have test only with all list reload and working.
commad = wget -qO - http://127.0.0.1/web/servicelistreload?mode=X
X=
0 reload lamedb and Userbouquets
1 reload only lamedb
2 reload only Userbouquets
I do not know if it's black list reload X >> 0 or 2
I have not test blacklist
Black Hole 2.0.8​
What is new:​
  • New Vu+ drivers 16 december 2013
  • New Skin MX SkyLine By Matrix10
  • New Bootlogo IOS 7 Style by mikark
  • Support wmv, wma, asf media file (duo, solo and uno have to be enabled in BhSpeedUp)
  • Update OpenWebIf
  • BhEpgPanel: Change internal openepg default channel to Nat Geo
  • Update languages fr, no, sv
  • Add Audio Effect Plugin
  • Transcoding : support multiple encoders
  • Transcoding : support resolution setting , and advanced setup
  • A/V settings : update.
    - add "AAC downmix" setup
    - fix entry name, Dolby Digital downmix -> Dolby Digital / DTS downmix
  • gstreamer plugins updated:
    - added support for mms protocol.
    - added patch related on rtsp.
  • Transtreamproxy updated.
  • Support more video codecs in media playback.(OE 2.1 gstreamer)
  • Reduce First picture display time(zapping time improvement : duo2, solo2)
  • Support dual transcoding(duo2, Only 2nd transcoding is mutually exclusive with PIP)
  • Improve PCM playback(solo, duo, uno, ulitmo)
  • Support 3D surround (solo, duo, solo2, duo2)
  • Support AVL(automatic volume leveler)(duo2, solo2)
  • Support more proc entries to control duo2 transcoding.(Plugin will follow)
  • Improve temperature control of dual tuner when not in use(duo2, uno, ultimo)
  • FPGA update in solo2(done automatically in the first bootup after installation)
  • Fix EOS deteciton in media(PCM) & TS playback
  • Support AAC passthrough
  • Remove unnecessary debug messages(duo2)
01-bootlogo-jpg.13970
shot3-jpg.13972
shot4-jpg.13973
shot5-jpg.13974
shot7-jpg.13975
shot11-jpg.13976
shot12-jpg.13977
shot13-jpg.13978
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
hi just wondering has anyone got problem with hardrive on any of the blackhole images i have tried 2.0.7 2.0.6 2.0.5 2.0.3 and every time i restart mt vu solo 2 i have to mount the hardrive everytime my friend has the same problem on vu duo any help
i just installed 2.0.8 on solo2.everything seems to work fine .i just changed the skin .Thanks a million B H( u r the best team ever )
BH commands
X=
Thanks!
I tried with all vaues (0,1,2) but didn't work for blacklist - tried to test it by switching blacklist to empty than filewith some channels.
Any other guess please?
The reload works fine from the parental contral panel menu.
