Black Hole Vu+ Solo2 v.2.0.8
It seems that YouTube has changed
and then the old plugin does not work just new.
But I have not tested with the old image, so I'm not sure
Hi!
I have a small problem with epg.dat.
When I save EPG to /media/usb/epg.dat, and I open the VU + ControlCenter I find epg.dat file in /media/hdd/ and not in media/usb.
With BH 2.0.7 is saved in media/usb.
Hi!
It's probably an old file.
epg.dat file you can only see at the moment
if you restart enigma ,start restart box etc.
At this point file goes into the memory
or from memory to the USB.
Even restarting the file is still in /media/hdd.
Is that I can cut/paste?
In my box not.
You use
BH EPG or CrossEPG ??
For BH EPG check Path in
Blue >> Red >> Red
for CrossEPG check Path in
CrossEpg >> Configure.
Check if your USB stick is well mounted
in Blue>>Blue>> Device Manager
In my box not.
You use
Blue >> Red >> Red
I use BH EPG
Blue >> Red >> Red : /media/usb/epg.dat
USB stick is well mounted : /media/usb
What is the problem Matrix10 ?:confused:
Check the creation date on epg.dat on hdd and, if you have it, also on usb key. Then try to delete epg.dat from hdd and reload bh epg.
Last, check again where your epg.dat is stored
Inviato dal mio GT-I9100 utilizzando Tapatalk
it is dated 21/12/2013
Operation success.:dance:
I deleted epg.dat in /media/hdd, then rebooted my receiver.
at the end I downloaded again epg.dat : now it's in /media/usb:notworthy:
Thank you to you and also thank you to Matrix10:yes:
Happy New Year for All.
I have no sound on old Mytube, new Youtube and TVPlayer. Solo2 is connected to TV via HDMI. Some videos in formats mp4, mkv are playing with no sound too.
Maybe you have to check your audio settings.
Try to open audio panel (yellow button) and to enable audio downmix (on).
Hello. Wish you all Happy new Year!!!
Congratulations for this new image.
I would like to ask, when will solo2 be able to have blind scan menu and if there is any way to reduce the time that receiver waits for signal on TP while searching. On satellites that have 100 frequencies and many of them are feeds and not always open, receiver completes the satellite scanning after 30-40 minutes, while other receivers that are simple and not e2 for the same thing need 5 minutes.
Thank you very much!
How do I use the Youtube TV in HBBTV? I have seen that is a new characteristic of BH 2.0.8.1
Thanks and happy new year
