Black Hole Vu+ SoloSE 2.1.1
Well i bought a Solo SE and went tothe website of open PLI.
I am new at the sattelite boxes, and tried the Original image on the Solo SE and i didn't like it.
A friend of mine uses Open PLI and advised me to use it.
So went to the website to download it, but no image for Solo SE, and they said:
Forum Moderator
PLi® Core member
Posted 24 July 2014 - 11:10
We haven't been asked yet, VU+ haven't supplied us with a BSP layer for it, and we don't have one to test it on.
So at the moment no plans and no date.
But i flashed the Black Hole image on it and i like it!
Maybe it's possible to make a XBMC addon?:p
Ok now I understand what you mean about BSP layer.
XBMC addon? What you mean?
VTI...okay image I suppose, but cannot be compared to Black Hole in any way! Nearly ten years with DB, then jumped the DB wagon for Vu+, and I have seen the light several years ago, with BH! Will never use anything else if I don't have to. Vu+ and BH is just miles ahead of the competition.
Hi,
It's my first Vu+ box and my first Black Hole image. It's huge. Everything works fine. Thanks for the hard work.
Hi guys,
I`m having problems with Vu+ Solo SE with cable tunner.
I change channels and in some channels I stay without signal, wait maybe 20 or 30 seconds and than the signal comes again. I have other boxes in my house ( Duo2 and dreambox ) and I know that the problem isn`t with the installation, because it works nice in the other boxs, I even switch places to confirm that.
So when will be na upgrade that corrects this issue?
I've found problem with DUAL DVB-T USB tuner. Unlike VU+ SOLO (old model) VU+ SOLO SE probably can use only first two tuners (internal and first of USB).
Situation: DVB-T tuners are detected all (both of DUAL USB), but at 3rd line is Tuner C: Dummy Tuner (not supported) and in fact it uses only the first USB tuner (using the first one is without any problems).
VU+ SOLO (old) with the same USB tuner (and the same version BlackHole image) is able to use all tuners (internal DVB-S2, +external DUAL DVB-T). It looks strange (paradox that old model can more then the new one). Is it some software limitation (but why?) or an error? And if error, is it BlackHole USB dongle support error (maybe this version? I've never tested any older in SOLO SE yet), or general "feature" of VU+ SOLO SE. I guess failing VU+ SOLO SE (or some fuckin' limitation). I've never had to add some special to BlackHole images, they support USB tuners. I've been sure, that BlackHole images is the best for it for many years. Is my opinion out of date and better to use other images? Thanks a lot.
