Black Hole Vu+ SoloSE 2.1.1
I've found problem with DUAL DVB-T USB tuner. Unlike VU+ SOLO (old model) VU+ SOLO SE probably can use only first two tuners (internal and first of USB).
Situation: DVB-T tuners are detected all (both of DUAL USB), but at 3rd line is Tuner C: Dummy Tuner (not supported) and in fact it uses only the first USB tuner (using the first one is without any problems).
VU+ SOLO (old) with the same USB tuner (and the same version BlackHole image) is able to use all tuners (internal DVB-S2, +external DUAL DVB-T). It looks strange (paradox that old model can more then the new one). Is it some software limitation (but why?) or an error? And if error, is it BlackHole USB dongle support error (maybe this version? I've never tested any older in SOLO SE yet), or general "feature" of VU+ SOLO SE. I guess failing VU+ SOLO SE (or some fuckin' limitation). I've never had to add some special to BlackHole images, they support USB tuners. I've been sure, that BlackHole images is the best for it for many years. Is my opinion out of date and better to use other images? Thanks a lot.
With latest Vu+ drivers for SoloSE box, the Vu+ Dev team has enabled 4 USB tuner compatibility on SoloSE boxes.
You can update manually drivers or wait next BH image.
