Black Hole Vu+ SoloSE 2.1.7
I'm very surprised that some people think that we can read in their minds ....
Thanks for your response.
Downloaded the image 2.1.7
Copied it on flash drive
Plugged in onto the solo se v2 stb
Power on
I have waited for 10 minutes and the front light indicator was slowly fading in and out.
I powered off the stb, removed the flash drive.
Power on back again.
Black hole image (the one with the star) appears and then it loads into the default VU+ interface.
NO Blackhole is loaded. (it only shows that first image upon startup and thats it)
How can I fix that?
Thank you.
Black Hole 2.1.7 MultiBoot
WHAT IS NEW
    • New switch from MeoBoot to OpenMultiBoot to use different kernels and drivers for each installed image.
    • New skin MX i6p By Matrix10
    • Vu+ drivers 20150623
      - Fix tuning problem(AVL6211, duo2, solose)
      - Improve vtuner(satip support)
      - Fix scrambling bit in recording
      - Improve transcoding
    • Xbmc Support 576/720/1080 resolution
    • Updated Vuplus-Blindscan
    • Updated HbbTv
    • Updated WebManual
    • Added Sat>Ip Client
    • Included UiPositionSetup
    • Removed MeoBoot
    • Added OpenMultiBoot
    • Updated Lcd4Linux
    • Updated MediaTree (usb tuners drivers)
    • Fixed random socket error
    • [ScanSetup] fixed error on complete scan with T2 tuners
    • [ScanSetup] fixed TT3L10 automatic scan problem
    • [unicable] support JESS(EN50607) and update unicable.xml
    • AnimationSetup: set default to animations disabled
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Hi
I am very happy with this image. However one little nag. When I use the media player for movie playback from my network. The sound starts to get lower as the movie goes on. Often I end up with the volume at max.
Anyone have the same issue and a fix?
Thanks
Hi guys, I am thinking of buying a VuSoloSE and I already feel I have a problem. I have found that there is 2 VuSoloSE, one with a single tuner and the other with 2 tuners. Now I was wondering which is for the one with single tuner and which for the bouble tuner. Thx for any help cause I feel a little confused. (BTW I looking foward for the single tuner) At the moment I have VuSolo and very happy with it no problems
Both boxes use the same images.
It auto detects which version of the box you have and will work fine.
